Leveling kit for an 07 H3?
Old Jul 26, 2008 | 08:02 AM
justanotherhemi's Avatar
Default Leveling kit for an 07 H3?
Well guys I have a 2007 H3 with an adventure pkg. Im not a big fan of the way the front sits lower than the back and was wondering where i could get a leveling kit? If someone could post pics it wouls be great. Thanks guys
Old Jul 26, 2008 | 11:43 AM
BRad's Avatar
Default RE: Leveling kit for an 07 H3?
turn yout tb 2 times that should do it
Old Jul 26, 2008 | 01:13 PM
gecko991's Avatar
You can level the front with your stock keys by just cranking them up a bit or just buy a set of Readylift keys which are slightly longer and can give a little more lift though you may want to change your front shocks as well. I went with the readylift keys myself as they give you a higher indexed starting point and Bilstein Cognito shocks on the front with a 3" extended shackle in the rear and RS9000XL shocks. The ride is actually better now and I have 35" BFG KM2s on stock rims. I still have more travel then stock setup and it looks wicked. 06 Birch White H3 Adventure
Old Jul 26, 2008 | 01:47 PM
veves's Avatar
ORIGINAL: gecko991
Hey can you post some pictures? also are the rear shocks you installed are they longer?
Old Jul 26, 2008 | 08:58 PM
GarrettMoore's Avatar
Just start by adjusting the stock keys.
There is no need to waste any money on a leveling kit.
Then, if you are unhappy with the ride, you can upgrade to the Cognito shocks.
Old Jul 27, 2008 | 03:23 PM
gecko991's Avatar
The RS9000XL rear shocks are about 31" long and have the flow speed adjustment ***** on the bottom.
[IMG]local://upfiles/5154/36B8F72035954D8799CDB3F4E90F1186.jpg[/IMG]
Old Jul 28, 2008 | 10:16 AM
Leveling Kit = 1 1/16" socket + socket wrench + a few turns on the T Bar bolts.
Depending on how far you go, get an alinement, and think about the cognito shocks.
Old Jul 28, 2008 | 11:10 AM
DILO's Avatar
This is well worth it and is done the right way im happy with mine.
http://www.readylift.com/c-70-h3-all-2006-2008-4wd.aspx
Old Jul 28, 2008 | 04:57 PM
gecko991's Avatar
The Cognito shocks are very smooth indeed.
[IMG]local://upfiles/5154/ED12A9299A7A4F8F881266981F7496B9.jpg[/IMG]
Old Aug 2, 2008 | 05:28 PM
jm4490's Avatar
JUST PUT ONE ON EBAY STORE NAME ARIBELLAS WHOLESALE
