Is this a leak, and is this bad....looking for advice.
Old Sep 30, 2017 | 12:36 PM
Optima's Avatar
Default Is this a leak, and is this bad....looking for advice.
After trying to resolve front end vibration issues and my tire guy showing me back and forth play in my front wheels, 2 separate mechanics told me..worn tie rods, worn upper and lower ball joints. The truck has 255k with original parts, so I wasn't surprised. I have ordered a ton of replacement parts already...steering rack (Delco with 16mm tie rods), Moog upper control arms, Moog lower ball joints, Moog sway bar links, and since they are in there...new bilstein shocks to go around.
i was under my truck today and saw alot of grease like material around drive train/axle? Sorry, I dont have the mechanical expertise to say what part, so I attached a picture.
Is the greasy area normal due to just driving and **** getting in there or is this all bad? Looming for some advice here. Thanks in advance.
Attached Thumbnails Is this a leak, and is this bad....looking for advice.-20170930_100910.jpg   Is this a leak, and is this bad....looking for advice.-20170930_100854.jpg   Is this a leak, and is this bad....looking for advice.-20170930_100849.jpg
Old Sep 30, 2017 | 01:09 PM
BruceS's Avatar
Looks like seapage on outer axle seal. Not bad yet. Clean with brake cleaner and rag. See if returns or gets worse
Old Sep 30, 2017 | 01:24 PM
Optima's Avatar
Since I'm having so much work done on the front end anyway, should I just replace it now and do the entire CV Axle. I see on Rock Auto, there are some selling in the range of 40-50 bucks. Also, I should only have to do this side right, since the other is completely dry and clean?
Old Sep 30, 2017 | 10:56 PM
BruceS's Avatar
I already replied to you in the other forums with links
Old Oct 1, 2017 | 11:49 AM
Optima's Avatar
Thanks bruce....saw that. You guys are awesome.
Old Oct 2, 2017 | 08:21 AM
No way no how would I put a cheap foreign made Half shaft (CV Axle) on my truck. Buy the AC Delco.
The taste of cheap immediately sours upon failure and repeat replacement.
honda400ex2003
19
Nov 5, 2015 09:40 AM
MissLove
Sep 22, 2012 11:28 AM
fishlunch
Oct 19, 2010 10:15 PM
giant H2
Jan 22, 2010 09:58 PM
HumminNBoatin
Apr 24, 2008 03:10 PM
