Leak?
Has anyone had trouble with water leaking from the roof console around the sunroof control and garage opener controls. I thought that maybe the sunroof was leaking but the sunroof doesnt even go up that far and the tracks of the sunroof are bone dry.
do a search in this forum for "leaks". You'll fing plenty of threads. First place to look would be the roof marker lights.
________ Threesome Fetish |
olfarts probably right i thought that my window was leaking and it was the marker lights. Take them off and re-seal them with marine silicone sealant
Same thing here pulled off the marker lights and sealed under them and the water stopped
I had the same issue as Hillbilly it probably your marker lights.
Roof marker seals or sunroof drains are the usual culprits.. :) J
I had the same problem. Front roof markers need gaskets resealed. You can try to fit a new gasket but good luck and hummer only sells you the entire marker kit $$$$$$$.
Originally Posted by CiscoH2
(Post 233928)
________ VAPIR ONE BAGS |
