knocking noise underneath while drive
Old Jun 23, 2013 | 11:59 AM
H2Miami's Avatar
Default knocking noise underneath while drive
Hi guys
Ive notice a knocking noise underneath while drive , I was reading that may be the mounts for the exhaust are broken or a problem with the shaft .
It is intermittent , most common while passing around the 45-50 mpg range
I will check the exhaust
Please any advise how to check if there is a issue with the shaft before taking it to the dealer
Any other thing to check ?
Thank you all
Old Jun 24, 2013 | 11:10 PM
rsmith77's Avatar
Crawl underneath with a rubber mallet and tap on a few things to see if anything seems loose or rattles. That would be my first guess. I would certainly check that before spending money at the dealership. But I refuse to go to the dealership in general...
The down tubes, or collector pipes from the exhaust manifold could be broken or loose which could cause the exhaust pipe directly under the area of the driver seat to come into contact with the second back latter looking skid plate under the truck. Might check the clearance between that pipe and the steel bar of the skid plate.
If it was the front drive shaft I would think you would have much more noticeable symptoms and much bigger problems. While you are under the truck make sure the universal joints all look good on the drive shaft.
Hope that helps, let us know what it turns out to be.
Ross
Old Jun 25, 2013 | 04:35 PM
Man1nboat's Avatar
I agree with Ross
tqu9047
Jun 12, 2015 10:17 AM
hulkh3
Sep 12, 2012 08:02 AM
rifsm1
Apr 7, 2011 11:06 AM
whododat
Aug 14, 2007 01:04 PM
sconnoll
May 18, 2007 05:27 PM
