Knocking at cold start-up remedy!
Old Dec 1, 2009 | 07:12 PM
quadblaster240's Avatar
Default Knocking at cold start-up remedy!
A lot of people are suffering from that lovely slight knocking at start-up. I have an 09 with 10k on it and its been doing it from day one. Well i found a cure...lucas oil treatment! The 32 oz. White squeeze bottle. Its been two weeks and i live in michigan so its down to 30 deg. At night and it hasn't done it since! I even run mobile 1 and it was still doing it. I'm gonna just add it after every oil change. It ranges from $9-$12. I THINK WALMARTS THE CHEAPEST!
Old Dec 1, 2009 | 09:32 PM
2wheelmonster's Avatar
What octane gas do you run?
Old Dec 2, 2009 | 05:37 AM
Black HUMMER's Avatar
If it only knocks or "rattles" for a second on a cold startup, it is probably your timing chain tentioner, which is a warranty repair.
The tentioner is actuated by the engine oil pressure vs using a spring mechanism. On a cold start, as in the engine has sat overnight, the tentioner will be loose and the chain will slap against the housing until the pressure comes up. What can happen is over time the chain will stretch but not enough for the tentioner to move up to the next cog or ratchet position as it is designed to do to accomodate the stretching.
Old Dec 2, 2009 | 02:49 PM
Or, it is the normal sound of an all aluminum engine with PCM controlled VVT cold start strategy program.
I'll spend your Lucas $$ on beer and not loose sleep over it.
Old Dec 2, 2009 | 05:52 PM
i never really lost sleep over it, i just really didn't like a new motor clattering. its under warranty so no biggy but what ever it was its gone now. i don't really think variable timing had anything to do with it but ....like i said it doesn't do it anymore...
Old Dec 2, 2009 | 05:59 PM
octane should only matter when the engines under a load hence spark knock, not at start-up, needless to say i have used premium also to no effect.
Old Dec 7, 2009 | 08:02 PM
update! truck sat two days , was 29 deg. outside , started it up........no knock! gotta love the LUCAS! if it was the timing chain tensioner it would have knocked. no oil treatment will stop that. go figure....
Old Dec 22, 2009 | 02:25 PM
ramirezjo's Avatar
which lucas oil treatment did you use? Did you use the full quart replacing one quart of oil? Would switching to 10w30 instead of 5w30 solve the knocking problem?
lostsoul77
Jan 25, 2013 04:39 PM
rifsm1
Apr 7, 2011 11:06 AM
WoogiesH2
Mar 8, 2011 09:58 AM
dilo2001gt
Apr 11, 2007 10:52 PM
Guy
Feb 22, 2007 10:21 AM
