knock sensor location
Old May 12, 2008 | 09:15 AM
alex2mil's Avatar
Default knock sensor location
I need to replace the knock sensor due to a p0332 code. Could anybody tell me where this sensor is locate at?
Please send me a pic if possible.
thanks
Old May 12, 2008 | 12:00 PM
Hummeron37s's Avatar
Default RE: knock sensor location
Before I got my H2, I had an Avalanche with a 5.3 (same engine as the 6.0) that the knock sensors went bad in. There is a TSB on the sensors. It takes about 3-4 hours to replace them due to them being under the intake manifold.
Old May 12, 2008 | 10:31 PM
Can someone tell me what a Knock Sensor IS/DOES????
Old May 12, 2008 | 11:19 PM
dizzy's Avatar
Ya. The knock sensors (2) are located under the intake manifold. I believe this can be removed as a unit including throttle body and fuel injectors. The 2 sensors should be connected by a wiring harness. Don,t know how easy this install would be though. See if a parts store can print off a diagram for you.
Old May 13, 2008 | 09:20 AM
TheFinestImage's Avatar
Funny thing, I just had mine replaced on my 07. I went wheeling last weekend, and my engine light came on. Dealer had to replace the evap canister, and the knock sensor and it's wiring harness. He said it was covered with too much dirt/mud, that it couldn't read anything. What happened to yours?
Old May 13, 2008 | 12:07 PM
alex2mil's Avatar
thanks to all,
Dizzy
are u sure there are (2) knock sensors?I need to order them, but I need to knowthe qty
Old May 13, 2008 | 01:17 PM
HumminNBoatin's Avatar
Bob,
A knock sensor is essentially a microphone that listens to your engine to detect knock. Generally it can detect a knocking rod or lifters that need to be adjusted etc...
I have no idea where the knock sensor is on the H2. My boat has a 5.7ltr 350 and the knock sensor is located on the side of the block just above the oil pan.
Old May 13, 2008 | 01:37 PM
Muddydawg75's Avatar
Old May 13, 2008 | 01:43 PM
pteam's Avatar
Is there a place to buy a whole wiring diagram / ulitmate book on the h2 for repairs / replacing hidden sensors etc?
Old May 13, 2008 | 02:09 PM
hummech's Avatar
there are two knock sensors. one for left bank and one for right bank. if you are in there i would replace both of them.
