K&N air intake or Safari snorkel????
Old Dec 9, 2009 | 09:36 PM
FUBAR's Avatar
Question K&N air intake or Safari snorkel????
which do you think would be better for more HP and better MPG?? I want the look of the Snorkel but do you have to cut into the fender/hood to get max air flow?? I know that the snorkel provides cleaner air b/c the air intake can trap oils and dirt from the engine. Any suggestions!? Thanks!! keep HUMMIN!
Old Dec 10, 2009 | 09:38 AM
Hummer Guy's Avatar
Personally, I always though the snorkel was a farce. I'd go for the performance air intake.
Old Dec 10, 2009 | 09:31 PM
GOFASTER's Avatar
I've got a K&N for sale in the classifieds for a 2006 H3. Check it out.
Old Dec 13, 2009 | 06:46 PM
2wheelmonster's Avatar
is it possible to do them both?
Old Dec 13, 2009 | 10:16 PM
DAGKANA's Avatar
2wheel... It is possible to do both, however the k&n is an open box design so you loose anything that the snorkel would possibly provide you with as far as keeping dust or water out of the intake. I think the best of both worlds would be an airdoc intake and a snorkel...
Old Dec 14, 2009 | 05:22 PM
ptcary's Avatar
I don't believe that the Safari snorkel is a "cold air intake" as much as it is for keeping water out of the airbox, but the experts here can correct me if I'm wrong.
If you are just looking for cold air intake, and are not doing a lot of off roading in dust, then you could probably make a cold air intake out of some vacuum cleaner pipe and fitting that goes from the factory airbox up to the front grille, then add a filter of your choice to the box. Again, this would not be ideal for off-roading.
Old Dec 14, 2009 | 06:07 PM
FUBAR's Avatar
ok, well i think I will attempt to do both since DAGKANA says that it is possible. Next question however, which air intake is better? air doc then buy a filter or volant air intake system? Im thinking volant? thanks for all of your guys input!!!
Old Dec 14, 2009 | 07:38 PM
DAGKANA's Avatar
FUBAR I'd say go for the airdoc... you're paying alittle more for volant if Im not mistaken. They have you change the air box and I can't speak to their quality, however I do have an airdoc and it does a perfect job, completely up to you.
Old Dec 14, 2009 | 09:39 PM
FUBAR's Avatar
sounds good, yeah the air doc is alittle cheaper just b/c I believe you have to purchase the filter seperate? Also Dagkana you may know...but where could I get, or who makes, a spare tire delete cover? Thanks again!
Old Dec 15, 2009 | 04:09 PM
DAGKANA's Avatar
FUBAR I don't think anyone actually makes one... in the past there have been forum members that have made they're own, and a common way to do it is a cookie tray (cooking pan) and using the mounting bolts for the stock carrier...
dbhoss@att.net
May 11, 2012 04:49 PM
Zipthelipp
20
Jul 31, 2011 02:04 PM
mastercraft88
Jan 23, 2010 09:37 PM
Dirtman2009
Jan 20, 2010 09:00 AM
importkiller
27
Nov 21, 2008 03:08 PM
