Just Got my H3 Woa! Need backup camera kit HELP!
I'm all for choosing a system that works best for YOU. As mentioned before, I believe that a system that WARNS you (idiot proof), is absolutely the way to go. The bumper hitch sensors look like a great solution. Same principle as mine. I probably would have purchased the hitch sensors if I would have seen it earlier.
IMO- No downside if you try the hitch sensors. It definitely looks plug-and-play. If you don't like it, package it back up and re-sell or return it then go to Plan B.
If you decide to go the CrimeStopper route, I saw them on eBay for around $53.00. It does come with a hole saw for the sensors. Sensors fit snug in the hole, but I used a little clear construction adhesive. The control module measures approx 3x2x.75. I mounted it inside the bumper (it's weatherproof). I popped the backup lens and tapped into the backup light wiring. Then I snaked the LED readout wire underneath the interior side molding up to and underneath the dash. 1.5 hours total. No big deal.
ORIGINAL: bonzaiii
Which wire did you tap into for the LED readout ?
CrimeStopper User's Manual
Fin, THANKS SO MUCH for all your help in pics and descriptions. You have been most helpful! I may consider this option and soon. I do survey my surroundings now before I even get into my H3 to back out after that embarrassing mishap...and of course "I'm an excellent driver" (and Kmart sucks too) LOL! [8D]
ORIGINAL: finskeeper
LED readout has a 50' lead and is powered from the control module. The only tap is from the control module power leads into one of the backup lights. There is also a little pizzo speaker (warning beeper) with about a 8' lead that I mounted just inside the rear cargo area.
ORIGINAL: bonzaiii
http://zalmar.com/detail-CarElectron...deo-HCUC_1.htm
I installed (actually Best Buy installed it for $150.00) in the plastic area above the license plate. to the right of the license plate light. The monitor was mounted in-line with the rear view mirror at dash level. It works really well and gives a really nice color view of everything behind you.
Zalmar.com was by far the best price I could find. I chose the UniCam so I could choose where to mount it. The hitch cam or license cam would be as good, and cheaper to install, but costs more to buy.
Thanks for the great picture of the sensor placement. I just got a set of 6 sensors from
2 for the front and 4 for the rear. When you plugged into the backup lights where did you do it and to which wire? I saw a message that mentioned the manual (p4-69) mentions the trailer hookups having a Light Green wire for the Backup lights. I was thinking about using this for the pwr but originally thought I should use a pwr wire near the backup lights. Just not sure how to go about finding it. I'm planning on messing around with it tomorrow. Please let me know how you hooked up your system to power the sensor when in reverse only. Thanks for the info.
Jimmy V
Jimmy V
