JL Audio Stealthbox????
Old Mar 24, 2009 | 05:12 PM
dschmit's Avatar
Question JL Audio Stealthbox????
The most recent post on this was in 2006 so i figure were do for a new one. So does anyone have this? And does it sound good? Is it worth it and how hard was the installation?
Heres the link if you dont know what im talkin about
http://www.crutchfield.com/p_1369419...ox.html?tp=113
Old Mar 24, 2009 | 07:56 PM
BrickWurX Mfg.'s Avatar
We played with one before purchasing an H3 with a non amplified stereo. They are made to fit in the factory sub area on amplified stereos only, so if you have two rear pockets in your truck it may not fit without some cutting. The single ten adds a good amount of bass if you only plan on running your highs off the factory or replacement stereo. I would definitely add an amp for the sub. JL makes great stuff. If you are going to add components or a four channel amp for your highs, this sub is much too little to keep up with the newer, cleaner, louder sound of powered highs.
Old Mar 25, 2009 | 08:31 AM
leasedh3alpha's Avatar
JL spends a lot of time tuning the box to the car. You will not get a better sounding sub if you tried to make a box. You NEED to put an amp to it, but it will blow you away. the best part of the sub is it replaces the factory sub, so you lose no space. If you don't have the monsoon salrady, then you need to replace the left rear plastic piece to one that has the cutouts for the Monsoon.
Old Mar 25, 2009 | 03:49 PM
dschmit's Avatar
I already have the monsoon system in there and was just looking for an easy upgrade...when i replace the amp should i just use the existing wires or run new ones?
Old Mar 27, 2009 | 09:49 PM
You will need to run new wires.
Old Mar 27, 2009 | 11:47 PM
Dosmangos's Avatar
I would say the jl audio stuff is the best , and add a 250 watt amp to the sub and and the 300/4 for the rest of the speakers
jmada
Feb 28, 2012 04:36 PM
giant H2
Feb 21, 2010 09:37 PM
odelcastillo
20
Oct 23, 2009 11:51 PM
gatorsdogg
Mar 27, 2009 07:57 PM
anthony42376
Sep 9, 2008 08:46 AM
