Jingling.............
Old Feb 10, 2012 | 01:50 PM
gotafish's Avatar
Default Jingling.............
Jingling noise goin over bumps, sounds coming from under drivers side door, any sugestions?
Old Feb 10, 2012 | 02:17 PM
drtom's Avatar
Banned
better get under and check loose bolts, like "ucp",,sheilds,etc b4 u loose sumpthin
Old Feb 10, 2012 | 03:14 PM
gotafish's Avatar
"ucp" tight,Tube steps, tight......
Old Feb 10, 2012 | 03:51 PM
you may want to check out the heat shields above the exhaust. Sometimes they have a tendency to rattle.
Old Feb 10, 2012 | 09:41 PM
lcurle's Avatar
check the bolts on the inside of the door where the arm is when the door opens, had a few come through here, takes a 10mm socket to tighten all the way.
Old Feb 10, 2012 | 11:09 PM
texan's Avatar
There is a bracket of some sorts for the e-brake line between the frame and body (if I remember correctly) a little behind the drivers side door. E-brake engaged, the line is tight and the bracket doesn't move. E-brake off, the line is loose and the bracket on mine hits the frame a bit. Not too bad, just a jingle/clank on bumps.
Old Feb 11, 2012 | 07:40 AM
Widespread Hummer's Avatar
Another stab at it... your pads are worn down and there is just enough room for the pad not mounted to the piston to clank around.
Old Feb 11, 2012 | 08:23 AM
gotafish's Avatar
Will check out suggestions, when weather subsides. Taped E brake bracket, will check muffler sheild, and door bolts. Brakes and New rotors just done .
Old Feb 11, 2012 | 09:51 AM
drtom's Avatar
Banned
Default Brakes and New rotors just done .
my rule one: for a new problem,always look at the last thing someone worked on.
from many years of handyman repairs,fixing what the pros took short cuts on.
gotafish
Oct 8, 2012 09:04 AM
ukpaul
Feb 29, 2012 06:37 PM
