interior light bulbs types?
Old May 17, 2014 | 02:08 PM
a7m1's Avatar
Exclamation interior light bulbs types?
Hi, i have just joined this forum. Seems quite lot of usefull information i'll learn here and will try to contribute with my experience,
i just acquired automatic 2009 h3 i really don't know which trim it is
sunroof
cloth seats
doorhandles are not chrome
doesn't come with fueldoor cover
has cruise control but no steering controls
inline-5 engine, plese help me defining my trim level
anyhow i am trying to install led lights into my interior
glovebox vanity mirrors floor and roof , trunk also basically all intrrior lights
i didn't really drove the car in night to make sure what lights does it have ;(
also i really would like to install led license plate lights
PLEASE SPECIFY WHAT SOCKETS DO THESE LAMB USE AND WHAT PLUG they need
i don't have the owner's manual
thanks,
Old May 17, 2014 | 03:02 PM
CS_ADVENTURE's Avatar
Search Results For "neo4-b" | LED Products | Super Bright LEDs
the 4 mm is what I used in the hvac, door switches, and headlamp switch.
the dome lamp, cargo lamp, and maps are either 568 or 211-2
floor is 194. The cluster and 4x4 switch require a little more work
Old May 18, 2014 | 12:34 AM
a7m1's Avatar
sorry for the confusion,
i don't intend to change any cluster or dashboard lighting
can you please mention other names for the plugs? like 194 is called t10
what is 568? and 211-2
thanks
Old May 18, 2014 | 12:35 AM
a7m1's Avatar
i found out 211-2 is festoon but what the length?
Old May 18, 2014 | 12:37 AM
a7m1's Avatar
one more question
what is the license plate light type?
will i get errors if i replaced it with normal not "error free or canbus lights" ?
Old May 20, 2014 | 11:12 AM
a7m1's Avatar
Update;
installed 2 map lights(in the front roof left and right, they are called map lights right?)
i guess 39mm 6 or 8 smd leds it looks like it can fit upto 42mm bulbs
left the dome light as it as
Installed t10 bulbs for the license plate i guess 9-smd bulbs
will take picture soon when it gets dark enough here
thanks
Old May 20, 2014 | 11:22 AM
the bulb application from superbright leds should give you all the info you need.
Old May 20, 2014 | 07:03 PM
LoJac963's Avatar
https://www.sylvania.com/en-us/appli...s/lrgmain.aspx
Best reference for vehicle bulbs, both interior and exterior
Old May 21, 2014 | 03:36 PM
lostsoul77's Avatar
Whats the trick to pulling out the 194 bulbs for the floor courtesy lights? I've converted both dome lights and license plate to LED but can not grip the 194 bulb for the floor lights and pull them out of the socket. Feels like they will shatter in my fingers if I squeeze too hard to grip and pull them out..
Old May 21, 2014 | 03:44 PM
unfortunately I have had that happen with different bulb types before. luckily I didnt need stiches. you can try laytex gloves to get better grip. or very carefully use a flat blade to gently work the bulb up.
