Interior LED Lights
Old Mar 12, 2011 | 10:41 AM
heyttsguy's Avatar
Default Interior LED Lights
Anybody replace the roof interior lights with LEDs? It's weird they don't seem to fully shut off after the doors are closed because of the low resistance I think. You put a regular festoon bulb in and then they shut off all the way, seems strange. Discuss...
Old Mar 12, 2011 | 03:51 PM
Broken Halo's Avatar
I've been planning on making the switch-over, but, now you've got me thinking!
Old Mar 12, 2011 | 04:26 PM
wfturner's Avatar
I changed out several interior and exterior lights on my 04 VW R-32 and the amp draw was so low on the new LED bulbs, that it was causing the CPU to trip codes. They did turn off completely tho.
The CPU would think bulbs were burned out or at least not working for some reason.
If you are getting some amp draw with the new LED's installed, that could be a problem
Have you tried testing the circuit with a volt meter after the doors are shut and bulbs should be off ?
Hopefully there should be no voltage at all
Good luck
Old Mar 12, 2011 | 05:49 PM
jrbnc's Avatar
Yeah I have the same issue. Replaced all my interior bulbs with LEDS. They don't seem to give off quite as much light but I'm liking the look a lot more. Anyway, my map lights with the buttons all go off completely but the 3 dome lights do not. I havent checked to foot wells to see if those are also still on or not. But the amount of light is barely noticeable, I had to point it out to people before anyone even noticed. At first I was thinking of getting a resistor like i needed to use for the front blinker LED's but I don't mind it and think I'll just leave the mood lighting as is. LOL.
Old Mar 12, 2011 | 06:56 PM
drtom's Avatar
Banned
Default xx a guess xx
mite be that they find a tiny leakage path thru the control circuits, a path not low enuf to lite a reg bulb but enuf for the led to come slightly alive. they will conduct with very lo volts. ?? actually lo current.
ill try to buy some and test it out
poway14
Jun 29, 2015 02:22 PM
poway14
Jun 14, 2015 03:43 PM
jamdd2005
Aug 12, 2011 11:30 AM
z
May 25, 2007 01:58 AM
HummerIvy
May 24, 2007 05:16 PM
