Intake & Programmer Selection
Old Mar 28, 2006 | 01:15 PM
MJ50's Avatar
Default Intake & Programmer Selection
I'm planning to add intake system and programmer.
I've narrowed it down to two choices.
1) K&N Performance Intake Kit + JET Stage 2 Performance Module
2) K&N Fuel Injection Kit + HyperTech Programmer III
I'm sticking with K&N since I did not have experience with AIRAID nor Volant.
I'm not looking for best gains, but noticeable. Appreciate any suggestions. Thx.
Old Mar 28, 2006 | 01:30 PM
shortbus's Avatar
Default RE: Intake & Programmer Selection
imo, the intakes are a waste of money, unless you're adding a supercharger. if it's an open intake, you run an additional risk of water ingestion. the gains are not significant enough to notice, unless you like the growl they make when you stomp it.
i got a noticable performance gain from the hypertech III, but it's still a rolling 7000 lb brick with the aerodynamics of a cinderblock. a bit more power and tighter shifts (i wouldn't recommend changing shift points though, it's not a race car), and a speedometer that's accurate again. the benefit of the hypertech is that you can easily restore factory programming if you have to take it in for maintenance, and if you trade your H2 for another one, use it on that one too. it doesn't lock in a VIN, but you do have to restore the programming on whichever vehicle you programmed first in order to use it on another one. basically meaning you can't program yours and someone elses at the same time.
Old Mar 28, 2006 | 05:29 PM
dilo2001gt's Avatar
are you older enough to drive
Old Mar 29, 2006 | 12:19 AM
Dennis's Avatar
ORIGINAL: dilo2001gt
Not sure either Mark..But MJ sure knows what kinda mods are needed for more power...been around the block you might say....Impressive.[sm=smiley20.gif]
Old Mar 29, 2006 | 02:36 AM
MJ50's Avatar
yes i am.
Old Mar 29, 2006 | 02:37 AM
MJ50's Avatar
just ordered option2.
can't wait to feel the difference.
ORIGINAL: Dennis
Old Mar 29, 2006 | 09:43 AM
dilo2001gt's Avatar
is that you in the pic if you don't mind me asking how old are you.
Old Mar 29, 2006 | 10:23 AM
Dennis's Avatar
ORIGINAL: MJ50
ORIGINAL: Dennis
Excellent..let us know how you like the performace...Have you, or are you planning on doing anything to the exhaust?..It almost goes hand in hand with the intake up-grade.[sm=gears.gif]
Old Mar 29, 2006 | 11:15 PM
shortbus's Avatar
do them one at a time, and let us know which upgrade gives you a noticable improvement. if your MAF goes TU, put the stock intake back on, warranty doesn't cover it if you've put an oily filter in front of it. i would have to agree that an exhaust upgrade should be included though. no improvement in performance if you go cat-back, but it sure does sound better . . . .
Old Mar 31, 2006 | 04:00 PM
MJ50's Avatar
no, the avatar is not me & i'm in 30s.
