Installing An Oil Pressure Gauge In H3?
Old Sep 10, 2011 | 01:46 PM
ak47dennis's Avatar
I would suggest going with an electronic gauge instead of the mechanical. I've seen/heard some real horror stories about the oil line coming off the back of the gauge......guess where ALL that oil gets pumped to.
I have been around muscle cars and 4x4's all my life and have never heard a story of that little tiny oil line "pumping" oil out on anyone and causing harm. I always buy a braided stainless #4 line. That copper or plastic line that comes with them is a joke.
Mechanical all the way
Old Sep 10, 2011 | 01:49 PM
ak47dennis's Avatar
how about the light auto dimmer? any interest,any ideas?
im figguring an adjustable delay,sensitivity,and a tube to sheild to start. then test with an led b4 flicking lites in oncoming eyes!
Not sure exactly what you're talking about. You mean something that would dim your brights automatically when it senses oncoming traffic?[/quote]
If you wish to have your new gauges have the same brightness as you factory gauges all you need to do is pull the headlight switch and probe it on the back side of the plug till you find the wire that controls the cluster lights and then turn the dimmer up/down to insure you have the correct wire, simple.
Old Sep 10, 2011 | 05:05 PM
Broken Halo's Avatar
Those first 2 'quotes' in your post weren't mine....they are drtom's. He's the one with the idea for this project, not me.
Old Sep 10, 2011 | 05:10 PM
Gee.....so I guess since you never heard of it, you're saying it couldn't possibly happen?? Exactly how much dirty engine oil would you say it would take for "that little tiny oil line pumping" to fukk up your carpeting??
Old Sep 10, 2011 | 06:55 PM
drtom's Avatar
Banned
! definetly taking a turn for the worse.
btw im talking about dimming my headlights,,,automatically,,no big thing
Old Sep 10, 2011 | 10:49 PM
rsc's Avatar
rsc
Nah, I'm not too big on all the auto-this and auto-that stuff in cars now days. Heck, this is the first auto transmission I've had in my own car! Auto lights? Sorry, not a fan.
Old Sep 11, 2011 | 11:53 AM
drtom's Avatar
Banned
Default back to oil pressure
looked at sending junit at a z . odd threads, same pitch as 1/2 npt, not metric, but looks like 3/8,not 1/2!!
found nothing to match.
at $35+ i didnt buy it to carry with me but it doesent look good,,,or ez.
Old Jan 19, 2016 | 07:04 PM
seavee04's Avatar
Default oil pressure switch
I just put a mechanical oil pressure gauge in my 07 H3 because my light would come on at idle.I first replaced the stock sending unit worked for 3weeks then started doing it again. The sending unit thred is 16mm b 2.0 and you cant find and adapter so I took my old sending unit apart drilled and taped the center to 1/4 npt and hooked up the mechanical. At idle it has about 15psi
Old Jan 19, 2016 | 10:21 PM
happythree's Avatar
good idea, 15 seems low but somewhere i read gm called for 10lb/1000 rpm. like 40 lb at 4000.
im used to seeing 40 to 50 cruising at 60 mph, around 2000 rpm in most vehicles i owned
what do you see at 2000?
id like to have a "t" and use both guage and sender.
if your light is coming on you must be low huh?
Old Jan 20, 2016 | 04:03 AM
Oil Pressure Sender Tee Adapter LS1 LS2 LSX | eBay
