Iddle and stall
Old Mar 24, 2011 | 11:55 AM
dafihummer's Avatar
Default Iddle and stall
After a couple of stalling incidents, checked all coil packs and found number 1 all rusty and changed it..Seemed to be the problem at the time.
But allas no, it stalled again last week..no shifting in rpm, just stalled when the car came to a halt..
Today, decided to give this issue more time, with my mechanic, took the throttle body off completely and gave it a good clean..It was not very clean..[ I have to say that we cleaned it before but without removal].
But now that it has been cleaned thoroughly, the starting and iddling of the car has dramatically improved..almost V smooth,well almost
Just to add to other TB threads, it pays to remove them and have them
cleaned properly..
Old Mar 26, 2011 | 12:03 PM
HazMat H3's Avatar
Are there any instructions out there on how to remove and clean the TB?
Old Mar 28, 2011 | 11:55 PM
downway69's Avatar
^^^^I would also like to know if there is any advice or instruction on how to remove and clean the throttle body
Old Mar 29, 2011 | 08:56 AM
Songman's Avatar
Originally Posted by jdbaker73
It was pretty simple to clean, just need flat head screwdriver and I think 10mm socket, disconnected battery, removed hoses, then removed box just in front of throttle body, then disconnected hose on throttle body, removed four screws holding throttle body on, laid a towel underneath and went to spraying with cleaner, used rag and hand to remove thin film and some build up especially around plate. It was a little tedious to get to some spots, but definitely worth for a few dollars for a can a throttle body cleaner and another few dollars for a bottle of MAF cleaner. Waiting to see now if it makes in difference in MPG. Definitely stopped the idle dip at stopping and improved overall throttle response.
I haven't done this but this is some instructions from someone who apparently did it that I had bookmarked. Looks pretty straightforward. Just like cleaning a carb. But if anyone had pictures or more detailed instructions I would love to see them too.
I have read over and over not to touch the MAF sensor with your hands and use a special cleaner on it.
Old Mar 30, 2011 | 10:45 AM
dafihummer's Avatar
engine is also much smoother now..
mr300
Apr 2, 2017 07:08 AM
jc06
Dec 11, 2012 01:22 PM
branstone
20
Mar 26, 2012 06:12 AM
joenuzz
Sep 18, 2011 07:39 AM
kitesurferphil
Oct 5, 2005 04:22 PM
