I want to convert my h3 to this
3 Attachment(s)
I know this is a h2 but I want to set up my h3 alpha to look like this with ride height and wheels, does anyone have any info on this hummer? I have the rancho lift kit on mine. what all would I have to do to achieve this look?
To each his own... Seems like a waste of a Hummer to me, but my thought is that you would first have to remove the Rancho lift and order a lowering kit. Then add some fender flates.
wow!! never saw a slammed hummer
maybe torsion bars and rear spring hanger mods? or bent springs might be ez |
Based off the way the front wheels are tilted, I would tell you it looks like it has air bags installed. I don't know if there is a direct bolt on kit for H3's, but a universal kit probably could be adapted if you have welding skills. You would basically be removing the torsion bar set up and replacing it with bags...
nix the lift kit, get some dropped spindles and coil overs. probably need a modified 4 link in the rear too. loose the steps and go with a molded running board / fender flare kit.
i don't think the h2 in that picture has dropped spindles and that's why there's so much negative camber. |
Hummer H2 Custom Diesel - 2005 - Pictures
08BCD122329438 That thing got 20mpg, 1400 ft/lbs trq. http://www.youtube.com/watch?v=xLJS2UCuFto 2005 hummer h2 predator motorsports sema showtruck the pinnacle of predator inc's capability. 6.6 lly duramax turbo diesel with 5 speed allison transmission, custom oversized oil pan , auxillary oil and transmission coolers with seperated dual cooling fans and switches on each, air ride suspension with reinforced rancho shocks with resevoir , ride height can be adjusted by 8 inches each corner is controlled indepently, dual air tanks and dual air compressors, hellwig rear sway bar, oversized custom differential covers, wilwood big brake kit front and rear with cross, drilled slotted rotors, body kit, front hood scoop , complete billet exterior and interior package, rear drop down tire carrier with fullsize spare, aluminum roof rack, piaa fog and spot lights, hid front lights and led rear lights, custom theft proof windows, suede headliner, navagation system, rbp exhaust and wheels, k and n cold air intake, third row seating, seats 6, dual aux fuel tanks with custom switches 1200 miles between fuel stops, custom tune which enables fuel economy or full map power with a swtich on the fly, triple locking torque convertor, custom satin black paint job, 2ok miles since conversion , over $120,000 spent on this once of a kind race truck. it took 3rd place in the Bullrun cross country rally . H3 with airbag suspension http://www.youtube.com/watch?v=DN89E9VOO1w |
I'll take that rancho off your hands lol
Do I win the door prize for guessing correctly?
Originally Posted by Mr. Fancy Pants
(Post 272357)
mike |
(Post 272357)
mike |
