Humming Sound
Old Sep 18, 2007 | 07:36 AM
Default RE: Humming Sound
Sometimes, if you get a spider web, dirt, a leaf, snow/ice.......anything on the rubber door seal, you can get an air buzzing noise from seal on the driver's door, top upper front corner. If you wipe it off with a rag or cleaner it will seal up tight again. Happend to me 3 times, no biggy.
Old Sep 18, 2007 | 07:37 AM
shaunskie's Avatar
I have the same problem,with mineitmine the tie down hooks on the roof there are four of them, the noise stops if you fit the ski box or put a rubber sock round them to close the hole in the middle.
Best of luck Shaunskie
Old Sep 18, 2007 | 09:40 AM
waynesoffroad's Avatar
It's the outside plastic pilar molding. It's a common problem. The tab on the roof molding cracks and causes the pilar molding to vibrate and make noise.
Old Sep 18, 2007 | 10:36 AM
alrock's Avatar
ORIGINAL: D VADER
Somehow a humming Hummer sounds appropriate
Guys, are your leaks also allowing water in?
No water leaks around my windshield. Of course, I think it's only been driven in the rain once since I got it in May. Kinda hard to do rain testing here in the desert. No leaks when washing it either.
[/align]
Old Sep 19, 2007 | 02:00 AM
ORIGINAL: blackstangs281
Maybe it doesn't know the words
(man, I can't believe no one used that yet. You guys are slipping.)
I can't believe ANYONE WOULD!!!!Name:  raspberry.gif
Old Sep 19, 2007 | 08:07 AM
blackstangs281's Avatar
ORIGINAL: HummBob
Old Sep 19, 2007 | 03:08 PM
greenshirt77's Avatar
Just asking- but are you guys sure that what you're hearing is not from the front bumper area?
My H3 hums like crazy at higher speeds, or even at lower speeds on windy days. What I'm hearing is definitely the wind whipping through the openings in the front fascia.
Just another reason to crank the stereo. I learned a long time ago that the best $ spent in a domestic auto is for a top-notch sound system. That way, you can drown out all the squeaks, rattles, and hums.
hulkh3
Sep 12, 2012 08:02 AM
jco
Aug 29, 2012 07:35 AM
CaseyW
Apr 17, 2012 09:20 AM
hilljob26
Oct 15, 2007 07:14 PM
Barry Weeks
Jul 31, 2006 07:04 PM
