Hummer key stuck in ignition. Solution Found. Video attached
Old Jan 22, 2016 | 11:09 AM
HummaLova's Avatar
Default Hummer key stuck in ignition. Solution Found. Video attached
I made a YouTube video covering a solution to a problem that a few others may have as well. After installing a new radio and getting everything put back together, I turned on the Hummer to make sure everything worked properly. When I went to remove the key from ignition, it would not completely rotate back to the off position. The hummer was stuck turned on while I looked for the solution. To install the new radio, it required taking apart center console and center panel covering radio and air vents. In this process I apparently pulled a very small pink wire loose from its connection, located under the center console, which was the root of the problem. Check out the video for more details about the problem and how to fix it in case it happens to you.
Thanks,
Master Mechanic Chase New
Old Jan 22, 2016 | 03:17 PM
honda400ex2003's Avatar
good deal, thanks for posting!
steve
Old Jan 26, 2016 | 08:01 PM
hmer's Avatar
i had the same problem and did a quik fix about a year ago i want to find the part number for that entire cable so i can replace it
nncanfarelli
Aug 4, 2019 09:27 PM
Odzihozo
Aug 16, 2013 10:14 AM
hummerhonduras
42
Sep 19, 2012 11:49 AM
ezspirit
Jun 29, 2009 07:13 AM
doyleh3
Apr 2, 2008 10:01 PM
