For Hummer H3 Professionals Only
Old Jun 4, 2013 | 07:30 AM
sheeko29's Avatar
Lightbulb For Hummer H3 Professionals Only
Dear Professionals ,
How to disable , deactivate or remove the Panic Alarm from the H3 Hummer
because i don't know and when opening the Fuses Box i found the Horn + Alarm in one fuse
Old Jun 4, 2013 | 08:24 AM
its wired into the bcm. the door jamb switches activate it. take a t15 driver and remove all 5 door jamb switches, unplug the connectors and tuck them in the holes(not too far so you can get them back out). close all the doors and activate the alarm.
1- no false activation= defective door jamb switch (you will have to plug them in 1 at a time and retry, to find the defective switch)
2- yes false activation= need to check further
GL
12volts white/black to orange (10A) + ignition harness
Starter yel/blk (not for remote start) - PCM, blue plug, pin 48
Notes: The PCM (Powertrain Control Module) is on the passenger side firewall under the hood.
There is a white/blue (to white) wire and a white/yellow (to white/black) wire at the ignition harness, or the BCM, gray plug, pins A14 and A42, that performs the following: key sense, second ignition, starter, and Passlock resistance. Refer to DirectFax document 1603 for remote start interface information.
The BCM (Body Control Module) is in the passenger kick panel.
Second Starter N/A
Ignition white/green to dk. blue + ign harn or BCM, gray plug, pin B8
Notes: The BCM (Body Control Module) is in the passenger kick panel.
Second Ignition see starter wire notes
Third Ignition N/A
Accessory white/red to brown + ign harn or BCM, gray plug, pin B7
Second Accessory N/A
Keysense see starter wire notes
Power Lock lt. blue - either kick or BCM, blk plg, pin A11
Power Unlock dk. blue - either kick, door harness
Notes: To unlock just the driver door use white (-) at the BCM, black plug, pin A12.
Lock Motor gray 5wi door lock switch in driver door
Unlock Motor tan 5wi door lock switch in driver door
Parking Lights+ brown + driver kick or BCM, blk plg, pin A48
Parking Lights- brown/white - switch or BCM, gray plug, pin A7
Hazards white - switch or BCM, gray plug, pin A48
Turn Signal(L) lt. blue (F), yellow (R) + BCM, black plug, pins A3, B1
Turn Signal(R) dk. blue (F), dk. green (R) + BCM, black plug, pins A19, B2
Reverse Light lt. green + driver kick, harness to rear
Door Trigger see notes - BCM, black plug
Notes: The LF door is gray/black in pin A32, the RF door is lt. green/black in pin A38, the LR door is black/white in pin A39, and the RR door is lt. blue/black in pin A44. Use all four wires and diode isolate each.
Dome Supervision white - BCM, black plug, pin A46
Trunk/Hatch Pin common with RR door trigger
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock with ignition and Passlock
Tachometer NOT pink or black ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. blue + switch or BCM, black plug, pin A37
Parking Brake lt. blue - switch or BCM, black plug, pin A31
Horn Trigger green to black - switch or BCM, gray plug, pin A25
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock
Part #: 556LW
Notes: See DirectFax document 1603 for wiring information.
Old Jun 4, 2013 | 09:58 AM
sheeko29's Avatar
GL
Second Starter N/A
Third Ignition N/A
Hood Pin N/A
Factory Alarm Arm
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Passlock
Part #: 556LW
thaaaaaaaaaaaaaanks i'll give the instruction to workshop so they can deactivate it
Old Jun 4, 2013 | 03:30 PM
Only for a factory installed system, aftermarket installers will wire the unit in, most anywhere... You have to poke around under the dash for non factory: wiring, connectors, relays, boxes, etc.... GL
Old Jun 5, 2013 | 03:21 AM
sheeko29's Avatar
please how much does it cost to change the bcm ?
Old Jun 5, 2013 | 06:11 AM
Aussie H3's Avatar
Why do you want to change the BCM??
Just follow the advice given and be done with it.
Just check the door switches and remotes and all will be fixed.
Why start another thread on the same topic as the other one you started
Old Jun 5, 2013 | 09:01 AM
staggs's Avatar
Because obviously the other posts is for the hummer novice and this one is strictly for professionals
Old Jun 5, 2013 | 01:32 PM
rsc's Avatar
rsc
Hummer Professionals? This isn't the link to the Craigslist ad???
Old Jun 6, 2013 | 12:32 AM
sheeko29's Avatar
hey i just posted the first one to find out the reason of the problem and that one just to get rid of it
and thanks to you all for your kind support for a newbie hummer user
Old Jun 6, 2013 | 01:30 AM
Aussie H3's Avatar
So have you done the basic checks and fixed the problem???
Or are you going tear out every other part of the Hummer instead??
