Hummer h3 2008 body lift
Old Nov 4, 2013 | 01:20 AM
willdoesstuff's Avatar
Default Hummer h3 2008 body lift
hey guys. Id like to do a body lift. Is there a reason why i can only find 1" body lift blocks?
I run 305/75/16 baja claws and would like more clearance when tight turning while 4wding. Has anyone done this?
Old Nov 4, 2013 | 06:05 AM
Bunger's Avatar
I did a 1" body lift on my H3. You really can't go any higher without running into problems with the length of brake & ABS lines and some other wiring, along with the steering shaft angles.
Body lifting, no matter how high you go, is not going to cure the major rubbing point in tight turns. That would be the sway bar. The sway bar doesn't move with the body.
Old Nov 5, 2013 | 03:31 PM
Ok, so did the 1" body lift do much? Are you runung stock suspension?
Iv got the oldmanemu 2" lift by arb. Goes ok but iv had the bushes replaced about 5 time due to
The steel bushes not being pressed properly. What size tires do you run? Cheers mate
Old Nov 5, 2013 | 06:46 PM
Bunger's Avatar
Stock suspension, torsion bar adjustment to level the front. Trailduty 1/2" extended bump stops & Rancho shocks on front, OEM shocks on rear. Daystar 1" body lift.
315/75/16 Goodyear Duratrac tires on OEM rims.
Demolish
Jan 9, 2012 07:53 AM
CyrusPaice
Hummer H3T
May 23, 2010 10:11 PM
dalandshark5
Jan 4, 2010 02:04 AM
fsr7
24
Dec 12, 2009 02:40 PM
waynesoffroad
Sep 21, 2007 01:12 PM
