hummer h2 front end
Old Oct 28, 2007 | 09:25 PM
shortbus's Avatar
Default RE: hummer h2 front end
i'm still using the stock keys, and i've been able to get mine level and have enough room for 37" tires. standard spring rear, no air bags. i think the truxx keys are a waste of money, stock works fine, but it's your wallet. my wife could adjust the stock setup, so anyone could do it. just give it a day or two and get an alignment.
Old Oct 28, 2007 | 11:52 PM
vilim12's Avatar
howd u do it using the stock keys, see my black h2 doesnt have this problem maybe its something they did when they put the rims on but my wifes is bugging the **** out of me, same year h2`s
Old Oct 29, 2007 | 03:38 PM
shortbus's Avatar
do you know what the torsion bars are? they're the round rods that connect into a hex "socket" on your lower control arm. crawl underneath and you'll see where the bars end in a cross member running from side to side under the truck. where they hit the crossmember there are 2 bolts in the center of the crossmember (one for each torsion bar). turn those clockwise to raise, counterclockwise to lower, the front end. i would recommend NOT cranking them all the way, and both will most likely not need the same amount of adjustment. before you do anything, measure at a spot above your tire to the fender, then measure again after adjusting. make sure you know where they are before you start so you know how much they've moved. another measurement would be from the ground to a spot on the fender, just make sure you take all your measurements at the same spot on the truck. i know there's a post in the forum that has a picture of the adjustment bolts, but i'm too lazy to look for it and i already know how to do it
Old Oct 29, 2007 | 03:41 PM
shortbus's Avatar
here's a pic i posted a while back. your truck may be a bit cleaner than this, but it shows the Tbar and adjustment keys.
Old Oct 29, 2007 | 09:31 PM
vilim12's Avatar
thanks alot man might check that out sometime tonight or this weekend
Old Oct 30, 2007 | 03:44 AM
ORIGINAL: shortbus
SOOOO.....DIRTY.......
Old Oct 30, 2007 | 09:11 AM
shortbus's Avatar
nah, that's nuttin' . . . . . you should see it now - got pine needles and branches hanging down from our camping trip over the weekend. rain washed most of the chunks off the top last night . . . . . .
Old Oct 31, 2007 | 12:32 AM
vilim12's Avatar
hahah it is pretty bad tho i thought i had a whole different car when i saw the bottom of mine compared to yours, i guess you got the rust and mud package lol, how many inches is urs from the fender to the ground?
CLajoie222
17
Dec 9, 2013 09:34 AM
federicoiz
Nov 19, 2011 04:08 AM
jen813
Apr 12, 2006 06:07 PM
usmcman001
Feb 9, 2006 12:06 PM
falcons28fan
Jan 18, 2006 10:29 PM
