Howstuffworks - Hummer 4WD Tutorial
Old Oct 23, 2013 | 08:40 PM
redneckhoosier's Avatar
Default Howstuffworks - Hummer 4WD Tutorial
Just came across this and thought I'd share. Trying to figure out noise in front end and as a noob was trying to understand difference between CV joint, half shafts, Transfer and Diff, etc. I found this very informative to include pictures! Even highlights the different 4WD, traction control and locker modes. Figured it would be a good post up in general for the newer owners.
Hopefully it's pretty accurate. HowStuffWorks "The Four-wheel Drive Hummer"
Old Oct 23, 2013 | 08:49 PM
Oops, should be http://auto.howstuffworks.com/four-wheel-drive.htm. Starts generic and gets to Hummer specific.
Old Oct 24, 2013 | 07:05 AM
Sgill's Avatar
Interesting,
But, how close is the H3 4x4 system related to the H1?
They claim the H1 is probably the best in the world.
What does this say about the H3?
Thank you
Old Oct 24, 2013 | 08:44 AM
I moved your thread to General Hummer Talk, because it is interesting info, but doesn't relate specifically to the H3. I guess people could say put it in the H1 section, but this is a good place for everybody to check it out.
I left a 10 day redirect from the H3 section.
Kudos on the find.
Old Oct 24, 2013 | 12:01 PM
happythree's Avatar
an important point,
h3,like h1 has a diff in the transfer case so both driveshafts can move at different speeds when turning on dry roads.
the point;
the front/rear diffs are either open or lockers but not any of the others mentioned.
ReadyGun
Dec 9, 2013 03:23 PM
Hummer79
Jan 1, 2013 04:59 PM
intogaming
Oct 28, 2011 12:30 PM
Sundrop Addict
16
Mar 2, 2010 08:41 AM
D VADER
17
Nov 5, 2007 03:56 PM
