Howstuffworks - Hummer 4WD Tutorial
Just came across this and thought I'd share. Trying to figure out noise in front end and as a noob was trying to understand difference between CV joint, half shafts, Transfer and Diff, etc. I found this very informative to include pictures! Even highlights the different 4WD, traction control and locker modes. Figured it would be a good post up in general for the newer owners.
Hopefully it's pretty accurate. HowStuffWorks "The Four-wheel Drive Hummer"
Oops, should be http://auto.howstuffworks.com/four-wheel-drive.htm. Starts generic and gets to Hummer specific.
I moved your thread to General Hummer Talk, because it is interesting info, but doesn't relate specifically to the H3. I guess people could say put it in the H1 section, but this is a good place for everybody to check it out.
I left a 10 day redirect from the H3 section.
Kudos on the find.
Kudos on the find.
an important point,
h3,like h1 has a diff in the transfer case so both driveshafts can move at different speeds when turning on dry roads.
the point;
the front/rear diffs are either open or lockers but not any of the others mentioned.
But, how close is the H3 4x4 system related to the H1?
the point;
ReadyGun
Dec 9, 2013 03:23 PM
Hummer79
Jan 1, 2013 04:59 PM
intogaming
Oct 28, 2011 12:30 PM
Sundrop Addict
16
Mar 2, 2010 08:41 AM
