How to replace cabin air filter
Old Nov 18, 2009 | 06:59 PM
atashashane's Avatar
Default How to replace cabin air filter
Hi Guys, I just find out this video on how to replace cabin air filter. Its relatively simple repair that can be done in a few minutes. I just don't know if that will work for hummer? Any suggestions? Thanks.
Old Nov 19, 2009 | 10:20 AM
calif phil's Avatar
If your Hummer has one it's inside the H2 on the lower portion of the right side dash. The filter sits verticle.
Old Nov 23, 2009 | 04:10 AM
D VADER's Avatar
The H3 doesn't have a cabin filter.
Old Nov 24, 2009 | 04:17 PM
2wheelmonster's Avatar
The only filter that the cabin might have is probalby in the fire wall where the blower motor gets air from
Old Dec 2, 2009 | 12:17 AM
zombiember's Avatar
Replacing your car's air cabin filter is a relatively simple:
1. Remove the main access cover, undo the cover fasteners to remove cover and side cover if needed.
2. Locate and undo retainer clip to remove air cabin filter, compare the filter size to the replacement filter and reassemble.
Old Dec 2, 2009 | 05:46 AM
D VADER's Avatar
You must be referring to the H2 as the H3 has no cabin filter.
Old Dec 17, 2009 | 07:28 PM
jurelut's Avatar
I am a non-smoker. The filters were pretty clean at 30K miles. You could hold them up to the light and see quite well through them. In fact I've set them aside for possible re-use.
The climate in New England is not very dusty and there are few gravel roads. I was not having any problems with feeling the AC, either. The reason for erring on the side of preventive maintenance was concern over getting my allergies riled up.
A friend who has a Subaru shared a similar story about his cabin air filter.
Old Feb 13, 2010 | 02:38 AM
KineIntiz's Avatar
Thanks to acai berry juice, after 41 years, I'm no longer a smoker!
Old Feb 13, 2010 | 06:26 AM
D VADER's Avatar
Angry
But you still SUCK!!
Old May 29, 2018 | 11:02 PM
Krod1181's Avatar
Hahahaha, wherr in new England do you live? I assure you, there are more dirt roads in new england than there are paved suburban area. You should take your truck on some adventures as it was built to do, leave your suburb in CT or Andover and drive a couple hours west or North and i assure you... YOU WILL find dust and dirt. My H2 gets dirrty. #useyourtruck
