How do I install transmission cooling pipes?
Old Apr 3, 2014 | 01:15 PM
jayhawk714's Avatar
Default How do I install transmission cooling pipes?
Can someone tell me how to replace the transmission cooler pipes that go to the radiator. Do I need to drain anything or just remove the old and install the new ones?
Old Apr 3, 2014 | 02:04 PM
Moved this to the proper forum, ain't even close to an FAQ.
Get ready for a mess, just remove them and swap, start the motor on a level surface and after you get up to temp, check the trans dip stick to see if you need to add a tad of fluid. Tip would be do one at a time because when you have two off at the same time it just leaks 2 Xs as much.
Old Apr 3, 2014 | 08:29 PM
jayhawk714's Avatar
Thanks Doc! Really looking forward to it!!!
Matt Pratt
Jul 15, 2020 10:36 AM
dizzy
Feb 27, 2018 01:48 PM
meh1510
Jul 27, 2011 09:53 AM
alwayskaos
Oct 5, 2006 12:39 PM
