How do I connect my iPod?
Old Sep 22, 2007 | 01:15 PM
Muddydawg75's Avatar
Default RE: How do I connect my iPod?
I used a different version... but I used a T-Tap off of my factory stereo harness.... B1 on my 03 H2....
Old Sep 22, 2007 | 01:26 PM
HUMMER DRIVER's Avatar
A cheap alternative is to use an FM transmitter for ipod. I hd one for my company car, stuck in my Hummer for a long trip to Moab and I was impressed. Sure it isn't digital but it wasn't bad either, especially considering is was about $25.00
Old Oct 1, 2007 | 01:21 PM
mountainbiker's Avatar
Muddydawg75 - my manual says B1 is "Battery Positive Voltage". I haven't hit it with a meter. Do you know if this voltage is constant (never shuts off) or is switched? It sounds like it is going to be constant.
Hummer Driver - while the FM transmitter is cheaper (and easier), you'll really appreciate the sound quality. I have a Pioneer unit in my Explorer, and you definitely will love the sound and the ability to control the iPod through the head unit.
Old Oct 1, 2007 | 02:13 PM
B1 is constant... you are correct.
Old Oct 5, 2007 | 03:48 PM
Did you guys get any alternator whine from the USA Spec adapter?
Old Oct 5, 2007 | 08:41 PM
I have an AXXESS adapter... but whine is usually a poor ground....
Old Oct 6, 2007 | 02:58 AM
Does your AXXESS adapter have a separate ground along with power? I have the DICE adapter. It has only has power (besides the OEM head unit connectors). So, I am curious if all these other similar adapters have a ground. I could throw a filter at it. I have sent an email to DICE tech support on this and a display issue, but they aren't very speedy in their responses. The web site says 1-2 business days. The last question took almost 2 weeks. Buyer Beware
Old Oct 6, 2007 | 09:36 AM
My AXXESS plugs into the factory harness with a pigtail for the AXXESS Digital interface. My XM plugs into the AXXESS, along with the Ipod. It couldn't be easier.
Old Oct 6, 2007 | 10:11 AM
Yeah, sounds it. I believe this is the unit JPCustoms sells. I had called them last year, but I think it was only available for the H2. Mine wasn't difficult to install just add it into the 24-pin harness and attach power. Probably will need to open the dash back up and add a filter or swap my power source to get rid of the alternator whine. It would have been nice to have a ground. Curious if the USA Spec model has a ground.
user 956363738
Sep 25, 2011 10:47 AM
PowayH3
Dec 8, 2010 02:40 AM
ivan3
Dec 13, 2007 04:50 AM
pexter
Aug 1, 2007 06:06 PM
Petracco
May 18, 2006 04:14 AM
