Horn sounds like it has a sock stuffed in it
I know our horns are already puny but mine now sounds muted.... You can barely hear it 6 inches away... Hopefully the jerk that I tried honking at saw my one finger salute! Anyone else had this problem? I briefly took a look but didn't feel like messing it it too much, especially since it should still be covered under warranty - but it almost looks like a lucky rock or something might have hit the horn as the housing looks pierced. Still not sure why that would stuff a sock in it though.
I went for the Wolo 225 T I found the best price at Auto Barn
Wolo Chrome Horns Set - WOL225-2T
It has a good tone and not that higher pitched european squealer sound. I already know the life expectancy of any motorized horn off road and did not want long trumpets blocking air.
These are loud 112 db and chrome (but not for long)
I put one in the stock location and used two of the thin brackets they send sandwiched together on the other side of the hood latch. I just clipped that fancy connector and hard wired from one the the other and used a double slide on connector to attach the second one. They don't come with a relay but they are the conventional style horn and I don't thing amp draw is a problem. Hard part was I could not remove my grill because of the winch and brush guard. I did unbolt it and could raise it up enough to get the horns in. They will not go thru the grill slots. I failed on pictures. Not much to see.
On to the next mod.
On to the next mod.
I have replaced every one of our wimpy H3/H3T horns since our first one in 2008. I used 1 FIAM Freeway Blaster - Low Note and 1 FIAM Freeway Blaster - High Note on all of them. I use the stock horn wire adn they have a great LOUD note to them. They don't sound as kool as Docs tripple Eldorado horns but I don't have the third trumpet horn......yet!
The 4 horn Caddy set is much easier to find....
CADILLAC FLEETWOOD DEVILLE ELDORADO 4-NOTE HORN SET | eBay
Tricia, GM Customer Service.
WOW that 4 horn set looks AWESOME!!!! Would you need to run relays in order to prevent current draw??? Good to know im not the only one who thought GM chinced on the H3 horn! lol They could have at least given us two horns, my goodness!
