Hood Handles
Old Aug 11, 2006 | 04:35 AM
GHummer's Avatar
Default Hood Handles
If I install hood handles then do I need make drill holes into the factory equipment?
In other words, what if I want to take them off later?
Old Aug 12, 2006 | 12:06 AM
ChevyHighPerformance's Avatar
Default RE: Hood Handles
I don't have them, but the ones I saw need holes in the hood louvers. My friend bought a set of handles from McMaster Carr (hardware supply company) really inexpensive that look very much like the ones advertised as the ones sold for the hummer.
Old Aug 12, 2006 | 12:26 AM
BlackH3CA's Avatar
Yes. You will need to drill into the plastic hood cover in order to attach the handels.
Old Aug 14, 2006 | 11:38 PM
auria's Avatar
there are many many different hood handles, so check them out unless you already know which ones you want.
Old Aug 14, 2006 | 11:45 PM
Dennis's Avatar
Remove Plastic Hood Piece
Open the hood and tap the three clips loose located at the rear of the part. Close the hood and pull the part loose. The instructions tell you to use a tool that won't scratch the paint to pry the clips loose. I assert that there is no such tool in existence and simply worked my way around with my fingers and popped each clip loose.
The Hole Template
The kit comes with a hole template that you can just tape in place. You may need to clean the plastic to get the tape to stick.
Drilling The Holes
The instruction called for a much larger drill bit, but I used a 1/4 so the fit would be tighter. Of course this means that you need to drill the holes dead center of the template.
Attaching The Handle
Here is what the under side looks like after installing the hex head screws.
Complete The Project
After attaching both handles just gently tap the unit back onto the hood.
Old Aug 16, 2006 | 01:21 AM
HummerGuy123's Avatar
hood handle are stupid
Old Aug 16, 2006 | 12:29 PM
Dennis's Avatar
Well that's one opinion[sm=shutup.gif]
Old Aug 16, 2006 | 01:36 PM
HummerGuy's Avatar
Just because your wife won't let you buy them doesnt mean you have to be jeolous
Old Aug 17, 2006 | 01:21 PM
G Man's Avatar
ORIGINAL: Hummerguy123
hood handle is stupid?
hood handles are stupid?
Old Aug 17, 2006 | 01:34 PM
Dennis's Avatar
Proper grammer is not stupid
Neither is spelling
