-   -   Hood Handles (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/hood-handles-1456/)
GHummer Aug 11, 2006 04:35 AM
Hood Handles
If I install hood handles then do I need make drill holes into the factory equipment?
In other words, what if I want to take them off later?
ChevyHighPerformance Aug 12, 2006 12:06 AM
RE: Hood Handles
I don't have them, but the ones I saw need holes in the hood louvers. My friend bought a set of handles from McMaster Carr (hardware supply company) really inexpensive that look very much like the ones advertised as the ones sold for the hummer.
BlackH3CA Aug 12, 2006 12:26 AM
RE: Hood Handles
Yes. You will need to drill into the plastic hood cover in order to attach the handels.
auria Aug 14, 2006 11:38 PM
RE: Hood Handles
there are many many different hood handles, so check them out unless you already know which ones you want.
Dennis Aug 14, 2006 11:45 PM
RE: Hood Handles
Remove Plastic Hood Piece
Open the hood and tap the three clips loose located at the rear of the part. Close the hood and pull the part loose. The instructions tell you to use a tool that won't scratch the paint to pry the clips loose. I assert that there is no such tool in existence and simply worked my way around with my fingers and popped each clip loose.
The Hole Template
The kit comes with a hole template that you can just tape in place. You may need to clean the plastic to get the tape to stick.
Drilling The Holes
The instruction called for a much larger drill bit, but I used a 1/4 so the fit would be tighter. Of course this means that you need to drill the holes dead center of the template.
Attaching The Handle
Here is what the under side looks like after installing the hex head screws.
Complete The Project
After attaching both handles just gently tap the unit back onto the hood.
http://www.rausite.com/photogallery/Hummer/DSC00251.JPG
http://www.rausite.com/photogallery/Hummer/DSC00244.JPG
http://www.rausite.com/photogallery/Hummer/DSC00254.JPG
HummerGuy123 Aug 16, 2006 01:21 AM
RE: Hood Handles
hood handle are stupid
Dennis Aug 16, 2006 12:29 PM
RE: Hood Handles
Well that's one opinion[sm=shutup.gif]:D
HummerGuy Aug 16, 2006 01:36 PM
RE: Hood Handles
Just because your wife won't let you buy them doesnt mean you have to be jeolous :D
G Man Aug 17, 2006 01:21 PM
RE: Hood Handles
ORIGINAL: Hummerguy123
hood handle is stupid?
hood handles are stupid?
Dennis Aug 17, 2006 01:34 PM
RE: Hood Handles
Proper grammer is not stupid
Neither is spelling:D:D:D
