Hood Blanket & Dynamat Installed
Old Aug 4, 2007 | 09:15 AM
D VADER's Avatar
Default Hood Blanket & Dynamat Installed
The I-5 engine is a bit noisey! I discovered GM makes a hood blanket and the hood is already pre-drilled. The blanket is on back-order but my friend Luke at Lindsay GM Cadillac has a way of getting back-ordered items. It cost me an extra $10.
For a little extra sound proofing I added some Dynamat that I had.
The blanket comes with the push pin retainers. The hole project took less than 30 minutes and one Budweiser.
The results were very pleasing. Sound was reduced to an acceptable level. Looks very good too. Total cost was about $100.
Old Aug 4, 2007 | 10:17 AM
671H3's Avatar
Default RE: Hood Blanket & Dynamat Installed
The blanket looks good! I wouldn't mind getting one.
Old Aug 4, 2007 | 10:29 AM
Looks REALLY GOOD!!
Old Aug 4, 2007 | 10:35 AM
Sugardaddy's Avatar
Looks good
Old Aug 4, 2007 | 10:45 AM
D VADER's Avatar
I'd like to pull back the carpet and get some dynamat up against the Firewall. That should help with engine noise as well.
Old Aug 5, 2007 | 09:57 AM
Good pics D Vader. Is the engine side of the mat finished with like a sealed foam.? In other word, can ya squirt it off and wipe it toget the winter road gerdoo off in the spring? [sm=vader.gif]
Good work too Bro.
Old Aug 5, 2007 | 10:08 AM
whododat's Avatar
I understand it would get rid of some of the noise, but wouldn't that make the underhood temp higher, which is something we try to avoid?[sm=smiley25.gif]
Old Aug 5, 2007 | 10:23 AM
Old Aug 5, 2007 | 11:16 AM
D VADER's Avatar
ORIGINAL: Doc Olds
Good work too Bro.
It's like a sealed fabric and should be easy to clean. Not sure about a high pressure cleaning. This is a OEM blanket by GM so heat shouldn't be a problem. A lot of the upscale cars come with them standard.
Lauxmi01
Oct 28, 2008 01:51 PM
Lauxmi01
Sep 25, 2008 09:07 AM
dilo2001gt
46
Jul 27, 2007 06:47 AM
D VADER
Jul 25, 2007 10:35 AM
CWO
Apr 20, 2007 12:35 AM
