High transmission temps
Old Aug 16, 2014 | 07:44 PM
09 Black H2's Avatar
Default High transmission temps
After the exhaust manifolds get fixed next step is to see why transmission temperature sometimes reaches 225 to 230 degrees. Engine stay cool but slowly rises as trans gets hotter. Have change sender out, and added deep pan with some reduction but not enough. What is your normal and hottest operating temperature. Thanks
Old Aug 17, 2014 | 01:41 AM
ak47dennis's Avatar
Up to 220 is usually fine. So your 225 -230 is sill within range.
Old Aug 17, 2014 | 04:32 AM
2004H2's Avatar
i installed a 8 inch/12 volt, power fan on my cooler, i never see it go over 200...and it helps the rad with some of that Florida heat.....lol........just to be on the safe side anymore....it has the towing package,used to start climbing when hauling the boat,no more....
Have a great day....Rick
2004H2/2006H3
Old Aug 17, 2014 | 06:14 AM
citiboy's Avatar
Mine normally stays around 90c to 98c the hottest.
Old Aug 23, 2014 | 10:11 AM
yoymon's Avatar
did you install aftermarket tranny cooler yet?, bypass the radiator all together, installed tru cool on mine and I never get above 125ish.. read this
Tranny cooler installation - Hummer Forums by Elcova
Old Aug 25, 2014 | 06:29 AM
elkgrunt's Avatar
Yes this is what I did and It has never been above 140, normally runs about 125.
RJ3607
Nov 18, 2014 08:28 AM
H2CANEPADESIGN
Jan 10, 2013 08:50 PM
kchummer
Aug 18, 2009 02:34 PM
RealJeep
Dec 16, 2007 10:44 AM
Grand
Aug 10, 2006 01:31 AM
