HID help ASAP Please
Old Apr 1, 2012 | 09:53 AM
Jlo1169's Avatar
Default HID help ASAP Please
Hey guys I got a set of hids for my fogs and lowers..I was wondering if I had to take off everything in the front such as the grill the piece under the grill and what not. Also how do you plug them in because it looks like it needs to be cut or something.
That's guys
Old Apr 1, 2012 | 10:55 AM
Jlo1169's Avatar
Also if you could any help with instructions or photos would be greatly appreciated. I have almost everything off and what not I just don't know how to get the bracket holding the lower piece off and how to connect the lights because it looks like it has to be spliced.
Thanks again guys
Old Apr 1, 2012 | 10:04 PM
heyttsguy's Avatar
what are we talking about here, HID retro fit? I took the upper grill off when doing mine although you wouldn't have to, just makes for a neater install. If you got a decent kit it should mostly be plug and play.
Old Apr 2, 2012 | 09:21 AM
Jlo1169's Avatar
Ya I got the kit from ddm but there are two wires on it that look like I need to cut others wires because there are two pronges.
Old Apr 2, 2012 | 09:10 PM
heyttsguy's Avatar
i think those are for your fogs, correct? had the same wires in mine. when you unplug the factory harness from the back of the fogs those prongs slide into it, that's what triggers your ballast to turn on and more than likely the power source for it.
Old Apr 3, 2012 | 09:24 AM
Jlo1169's Avatar
hmm what part does it plug into because i cant locate an exact spot i think it would go and i obviously dont want to force anything
Old Apr 3, 2012 | 01:14 PM
wfturner's Avatar
If you got them from DDM, why can't they instruct you as to where certain wires need to go ??
Old Apr 3, 2012 | 09:09 PM
heyttsguy's Avatar
should be the harness that plugs into the back of your stock fog light bulb
CurtisP87
Mar 4, 2015 05:35 AM
Fahad
Dec 1, 2009 03:54 AM
hotrod
Feb 17, 2009 06:50 PM
pteam
Sep 8, 2008 12:37 AM
importkiller
Jul 26, 2007 02:21 PM
