help programing new keyless h2 remote
Old Apr 5, 2010 | 05:48 PM
E T H's Avatar
Default help programing new keyless h2 remote
Hi guys I need help to program new keyless remote for H2 2006 I purshased the remote from ebay I did what is written on the paper how to program no result first when I put the key in the ignition and hold the unlock buttom I pressed for almost 2 minutes no signal to start any help
thanks
Old Apr 5, 2010 | 06:25 PM
mfish's Avatar
I dont mean to sound like a smart *** but did it come with a battery?
I have one I have been meaning to program but I havent got around to it...
Old Apr 5, 2010 | 06:56 PM
markushp's Avatar
Hi, I used these instructions on my 2004 H2 some months back, worked without a hitch..
http://www.justanswer.com/questions/...r-my-hummer-h2
Good Luck
Old Apr 5, 2010 | 09:31 PM
E T H's Avatar
but when you put the key in the ignition and you press the unlock buttom you should have a sign to tell the system is ready no ?
Old Nov 18, 2013 | 08:48 AM
Celina Wakley's Avatar
thanks
Check out key fob instructions for keyless entry..
Old Nov 19, 2013 | 01:53 AM
Nate2106's Avatar
Hey guys, this may sound stupid but do all H2's come with the keyless entry feature?
Old Nov 19, 2013 | 02:27 AM
fyr145's Avatar
According to the spec sheet...............
Yes, all H2's came with the keyless entry system as a standard feature.
Old Nov 19, 2013 | 03:09 PM
Man1nboat's Avatar
I had to take mine to the dealer and they programmed it for $45.
Old Nov 19, 2013 | 07:11 PM
fyr145's Avatar
1. Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by door locks locking and unlocking automatically. (If locks do not cycle after you let go, not before you let go of the unlock button, then the vehicle has not entered programming mode and you must start procedure over. Remove key from ignition, open drivers door and return to step 1 ). If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
Old Nov 19, 2013 | 08:22 PM
Man1nboat's Avatar
I did try that and it didn't work for me. Good post though
