HELP with a possible oil overfill!
Old Nov 5, 2008 | 08:33 PM
Barefooter's Avatar
Default HELP with a possible oil overfill!
Ok, I just finished changing the oil on my 08 H3 per the awsome instructions with pics on here. I did the change with 6 quarts of valvoline full synthetic, but when i read the dipstick, it is so clear that I can't tell if there is not enough oil, or the L-F indicator is completely covered. Ithink, and am concerened withitbeing covered, so I poured all the old oil back into the containers to see if 6 quarts came out. It looks like only 5 1/2 came out, but I also had a spill from the oil shooting out to the side when I took the drain plug out (i did not read the addition comments section, or i would have know that). It also doesn't help that I am doing this at night and my only source of light is a halogen construction light. Any thoughts on this causing any serious damage? The wife is leaving for work before the sun comes up, and if I tell her she can't drive it, she may run me over with it. J/k, but she does love it that much.
Old Nov 5, 2008 | 09:18 PM
James Coker's Avatar
Default RE: HELP with a possible oil overfill!
You should be fine. Start the engine let it run for a minute then shut it off remove the dipstick clean it off and reinsert it and then check it, you should be able to get a reading or at least see some air bubbles on the dipstick.
Old Nov 5, 2008 | 09:31 PM
Six quarts with a new filter is fine. BTW I usually put in 5.5, maybe 5.75 and check the level, it is not quite full, so 6 Qts is good.
rhill20
Jul 1, 2013 12:23 PM
drtom
Jan 17, 2011 09:23 PM
LGK
Oct 3, 2010 04:09 PM
rodney960
Dec 15, 2008 03:56 PM
hummer07
Nov 18, 2008 10:46 AM
