HELP PLEASE!!!
Old Apr 15, 2008 | 03:52 PM
dwaxman1's Avatar
Default HELP PLEASE!!!
Need a copy of the wiring diagram for an overhead light pictured below, emailed, faxed, anyway but need it quick to rewire the one I have, anyone have this?? PLEASE HELP!!!!
Old Apr 15, 2008 | 07:07 PM
dwaxman1's Avatar
Default RE: HELP PLEASE!!!
no one have this wiring diagram still??? DAMN!!!
Old Apr 15, 2008 | 07:21 PM
blackstangs281's Avatar
Not me..........sorry
Old Apr 15, 2008 | 07:34 PM
dwaxman1's Avatar
ORIGINAL: blackstangs281
thanks anyways brother, i hope someone still has it laying around
Old Apr 15, 2008 | 08:35 PM
RickLF's Avatar
I rewired mine....for my Lightforce Lights....I will look to see if i still have the paper that came with the Extra wiring kit.........for the over-head lights tommrow......(Stock)
What lights are you going to Install.................OEM or something else....
If its something else..let me know.......I will explain what i did to make them work with there Exsiting wireing from Hummer........
RickLF
Old Apr 16, 2008 | 02:32 AM
Sorry WAXY!!!!
Old Apr 16, 2008 | 05:43 AM
dwaxman1's Avatar
WHat happened is this, I have the over head lights but some a$$ cut and took the connector, I took it to my custom shop to change the end connecto and also replace the wiring becuase it is looking abit woren, anyways the custom guys removed it all and now all I ahve are the lights up top, no wiring. the problem is that they are now on vacation and I want to head up north for the weekend, might need the lights, I have a buddy who will rewire it with new wires and relays but not sure where everything wires into, on the truck that is, that is why I am hurting here.
Old Apr 16, 2008 | 10:20 AM
dwaxman1's Avatar
bump
Old Apr 16, 2008 | 06:35 PM
RickLF's Avatar
Sorry waxman.........I looked everywhere for the Instructions but cannot find them.......
I know the feeling....
Worst case serernio, ground your Lights to the Screw that holds down the Light bar rack, Then run afeed wire with aIn-line 30 amp fuse to theBattery post, using aclip to the battery........or into the fuse box for Temp. fix............if needed......
Just a Suggestion.........
It took me 17 hours to rewire the light bar and truck, to my spec.s using 10 Ga, Marine wire (tinned) with Bocsh relays and Org. Hummer switches....50 Amp Fuse.....Lots of Shrink-tubing...Each light Draws 12 Amp to start and 9 to run........
Needless to say it has a Lot of power on the roof.........and room for More......
Hope some one else can help..........RickLF
Old Apr 16, 2008 | 06:57 PM
dwaxman1's Avatar
thanks Rick, that was my plan with a 30 amp relay and 30 35 amp fuse for teh 4 overhead lights, each one of these draws 5 amp
