HELP! my dash display says"replace lift gate fuse"
Old Sep 29, 2007 | 02:07 PM
gio's Avatar
gio
Default HELP! my dash display says"replace lift gate fuse"
my dash display says"replace lift gate fuse" in the message center on start upeven thought the lift gate lock works fine?iv checked all the fuses next to the drivers side dash and all the ones under the hood next to the battary. i called the dealer, the fuse they told me to check is fine they told me it could be the switch to lock and unlock the rear gate but that works fine too. every thing works fine put this display wont go away and im sellling my 2004 h2 to buy an 07 and this display is scaring away buyers anyone had trouble with this before or know somthing else i could try to fix it?
Old Sep 29, 2007 | 02:27 PM
Muddydawg75's Avatar
Default RE: HELP! my dash display says"replace lift gate fuse"
It's on page 3-50 of the owners manual. It says to replace the fuse... if it returns after replacing the fuse then see the Dealer.
It refrences 5-103 and 5-107 for fuse locations.
Old Sep 29, 2007 | 02:55 PM
gio's Avatar
gio
sorry i dont have my manual. these fuses are in the fuse box under the hood or in the cab?
Old Sep 29, 2007 | 03:01 PM
You can get online access here.... you might need the pictures to be 100% sure...
https://www.mygmlink.com/main/US/en/gmc/home
Old Sep 29, 2007 | 03:16 PM
gio's Avatar
gio
ok i found it yes that the same one fuse the dealler told me to replace the ecc fuse. it didnt work this sucks
Old Sep 29, 2007 | 06:16 PM
Does it clear and then come back?? or does it not clear at all??
Disconnecting your battery for a few minutes might help if it's not clearing at all...
Old Sep 30, 2007 | 02:59 AM
SuperMuddy!!!!
Old Sep 30, 2007 | 07:15 AM
I hate those DIC messages.... they are as bad as the Check Engine light when you know nothing is wrong....
Old Sep 30, 2007 | 09:18 AM
hilljob26's Avatar
disconnecting the battery and hooking it back up should do it
Hummerrican
Jun 24, 2015 07:47 PM
Jogi
Dec 24, 2012 08:10 AM
Phil
Nov 2, 2011 07:24 PM
jbs45
Jan 24, 2011 09:09 AM
peliti27
Aug 2, 2007 03:14 PM
