Help cleaning it up
Old Apr 10, 2011 | 07:56 PM
CARdiac's Avatar
Default Help cleaning it up
This is my install for my scangauge... I know, my hands are not the steadiest. Is there a trim i can put around it to clean it up?
Old Apr 12, 2011 | 05:01 PM
Hummphrey's Avatar
Sorry if this is a dumb question but what part is that being mounted in? and is the scanguage a pressure fit or does it get mounted with something?
**edited**
i ask because i was thinking of a more difficult way fix it... it would probably be a pain.
the easiest way is to buy a sheet of flat thin ABS plastic (like an 1/16 of an inch thick). cut so it fits tight around the top and both sides of the scanner and hot glue that sucker to cover the cuts you already made. it won't look perfect but at least you have something that will cover the cuts you made and it won't require you taking more off of what you already cut to smooth the edges.
That makes perfect sense in my head hopefully you understand what i'm trying to explain!
Old Apr 12, 2011 | 05:25 PM
Buy a new DashStar for $25-$30 and let someone else do the cutting.
Old Apr 12, 2011 | 05:29 PM
Hummphrey's Avatar
Tainter: is that what the unit is mounted in now (a dash piece)? I dont know why but I just cant tell what piece that is.
**edited**
I see what it is... yea thats definately the way to go.
Or if you really want to cut it yourself you can mark it off with a pen or pencil and score very slowly and softly with a blade and as you get the straight line, follow the mark you made and press harder each time you go over it. Eventually you will cut through the plastic.
Old Apr 12, 2011 | 11:26 PM
drtom's Avatar
Banned
Default ??????????
where the hell is it? on a hummer or your lawn tractor!!
i cant figure it
mt2ut1
Jan 1, 2017 10:07 PM
user 956363738
Jan 9, 2012 07:22 AM
schummer
Dec 24, 2006 12:54 PM
importkiller
Sep 14, 2006 07:53 PM
Autogeek
Aug 6, 2005 03:35 PM
