Help!
Old Aug 23, 2007 | 10:09 AM
atomicsedo's Avatar
Default Help!
[align=left] When I got into the H3 after a heavy rain the driver’s side floor was 1 inch deep. I found That one of the two drain holes at the front of the sunroof is stopped up. I jacked up the Left front so the rest of the water would drain out the hole on the right. Does anyone know Where that hole goes and would it be better to stick a wire in there or blow it out with a Air hose? Anyone else have this happen? [/align]
Old Aug 23, 2007 | 10:20 AM
D VADER's Avatar
Default RE: Help!
Mine did it but the sunroof wasn't completely closed. I'd use air instead of a wire.
Old Aug 23, 2007 | 10:23 AM
atomicsedo's Avatar
Default RE: Help!
[align=left]I thought that it was open also but when I looked up there the water was standing and you could see the hole was not draining.
[/align]
Old Aug 23, 2007 | 10:26 AM
D VADER's Avatar
Default RE: Help!
ORIGINAL: atomicsedo
[/align]
Mine looked to be closed but in a No Touch car wash the water came pouring in. I hit the close button and it moved just a tad and the water stopped. What did you do about all that standing water in your car?
Old Aug 23, 2007 | 11:21 AM
atomicsedo's Avatar
Default RE: Help!
Sears shop vac did the job well
Old Aug 23, 2007 | 11:24 AM
tmoody's Avatar
Default RE: Help!
well be sure to pull out the carpet (if you can) and get underneath at the floor pan as well........if not, it's going to get mighty "ripe" in the truck with some good ol' mildew at the carpet and pan.
Old Aug 23, 2007 | 04:06 PM
atomicsedo's Avatar
Default RE: Help!
I sure wish I knew where the bottom end of that tube is and how to get to it.
importkiller
29
Jan 15, 2008 02:51 AM
