Help!
Old Jan 23, 2014 | 09:33 AM
If your radiator is not leaking (or loosing fluid) then you do not need a new one. Find a different mechanic.
Old Jan 23, 2014 | 10:36 AM
Derian06's Avatar
I confronted the mechanic about the 900$ radiator and he said it was 511$ because of warranty. Then i asked him why he thought it was the radiator and he couldn't give me an explanation. I took my car out of the shop and brought it to a new mechanic, and he'll get to it in a day. Hopefully this one will be more trustworthy. Thank you all for your help!
Old Jan 23, 2014 | 11:58 AM
Hummin0814's Avatar
On your tire pressure monitoring problem, there is a test that you can do and it will tell you which tire it thinks is the problem. You can also determine if you have a faulty sensor (like I do). If your tires are properly inflated, it may be a bad sensor.
The TPMS check is in your manual and also somewhere on this forum. Just search for TPMS and you should find it. Good luck!
Old Jan 23, 2014 | 06:34 PM
Caraddict's Avatar
Keep up posted...good luck!
Old Apr 14, 2014 | 05:59 PM
norinco3264's Avatar
Any updates derian to the p0300 and p0305? I just got these codes for the first time ever on my 06 h3 with 63500 miles. I had just recently cleaned the throttle body and replaced plugs, so for now i switched coil pack 5 with 4 and cleared the codes. Hasnt came back yet. I bought an additonal coil pack just in case.
importkiller
29
Jan 15, 2008 02:51 AM
