Help
Old Jun 5, 2012 | 09:27 AM
nflowers77's Avatar
Default Help
hi i have a 2005 h2 but im having problems with my AIR suspension sometimes it goes up and stays up for months but then it goes down and wont come back up it would stay down for a long time then all the sudden it goes up on its own its down now can anybody help?
Old Jun 6, 2012 | 09:00 AM
hobcog2000's Avatar
probably a bad level sensor in the rear try disconnecting the plug and clean the connections and put some electrical greese on it might solve the problem if not replace the level sensors cost 100 a piece takes about 10 mins you can do it yourself with a socket set
Old Jun 6, 2012 | 10:52 AM
nflowers77's Avatar
Thanks is it one sensor for each side and u have a idea how it looks for i can find it
Old Jun 7, 2012 | 07:38 AM
hobcog2000's Avatar
yes one on each side if your facing the rear wheel its a lever with a rod black in color and plastic, if your staring at the tire as its a clock it would be on the frame at about 11 oclock in the rear wheel well
Old Jun 7, 2012 | 06:47 PM
Mr. Orale's Avatar
I was having a similar problem,thank you for that sir.
Old Jun 8, 2012 | 12:25 PM
hobcog2000's Avatar
no problem
Old Jun 19, 2012 | 08:22 AM
nflowers77's Avatar
Default Fixed
Thanks buddy it was a bad connection on the sensor
Old Jun 20, 2012 | 10:14 AM
hobcog2000's Avatar
it usually is glad to hear it was a cheap fix
importkiller
29
Jan 15, 2008 02:51 AM
