HELP! 03 in limp mode and key stuck!
Old Apr 25, 2017 | 08:35 AM
kitcheneater's Avatar
Default HELP! 03 in limp mode and key stuck!
03 H2, Check ENG Light is on, codes are as follows: P0740,P753,P058,P0785,P1860
I changed out the ignition switch, still in limp and key won't come out. I checked the wires under the shifter, they look good.
HELP!! please
Old Apr 25, 2017 | 09:24 AM
I've researched the heck out of this and can't find the elusive wire that might be causing the issue.....
Any help will be greatly appreciated!
Old Apr 25, 2017 | 10:27 AM
S Reynold Gudam's Avatar
Have u check the shifter cable underneath ur truck where it connect to ur gearbox? hurm... also, since u've changed ur ingnition switch,please look for info regarding immobilizer.
Old Apr 25, 2017 | 10:34 AM
I have not checked the shift cable, I will, though! It drives and sets into park just fine, doors unlock and the shifter works as it should, it seems.
I'll search the immobilzer now! thanks!!
Old Apr 25, 2017 | 10:52 AM
https://www.hummerforums.com/forum/h...se-help-27371/
this dude had the EXACT same issue, ignition switch fixed it, mine...NO. SO it has to be a wire, correct?! or could it be the lock cylinder?
Old Apr 25, 2017 | 12:22 PM
Pull the shifter handle off (allen screw on the upright part of the shaft), then pull the cupholder/shifter cover off. Check the wires under there. One of them is a shifter interlock sense and if it comes loose or gets cut you cannot remove the key from the ignition.
Old Apr 25, 2017 | 02:36 PM
thanks! I have all that apart and will check the pig tails and connections. The truck runs 'fine' and I can manually put it in FIRST ands it will down shift to what I think is 2nd.... but the codes still there and key still stuck ... I'll check the wires and update!!!
Old Apr 25, 2017 | 02:39 PM
would this cause the Transmission to freak out as well??
Old Apr 25, 2017 | 03:54 PM
That I'm not sure of.... I think the shifter interlock can prevent you from either putting it into park or taking it out of park and also will prevent removing the key.
Old Apr 26, 2017 | 07:57 AM
Agreed! that's why my thoughts are the it HAS to be a wire, the tranny isn't getting power!
