Heated Seats issue ...
Old Dec 18, 2017 | 09:09 AM
dkb123's Avatar
Default Heated Seats issue ...
Hey guys ... finally getting around to fixing my heated seats (07 H2).
Starting condition: drivers side adjustments work ... no lumbar ... no heat top or bottom. Passenger side lumbar works ... no heat.
So I had a pretty good guy look it over and he got the lumbar working and the seat tops working but both bottom seat elements won’t heat?
Is that a sure indication that the seat elements are bad?
Have read on the forum that a bad relay under the dash can cause intermittent operation of the seats?
Trying to figure out where to go next and how far to chase this thing ... knowing my dealer ... he will suggest I buy entirely new seats for $5,000
Old Dec 27, 2017 | 09:35 AM
LoJac963's Avatar
If they are the original seats the elements are probably shorted/broken somewhere causing them not to heat. I would definitely not buy new seats but go to an upholstery shop and have the seat cushions and heating elements redone. I doubt any dealer even has H2 seats anyway.
Old Dec 27, 2017 | 12:28 PM
tharber's Avatar
Check the 'breakers' that control the seat functions. There is one down at your left foot and one under the hood. They are metal cased and do go bad.
I found that I kept using the foot panel as a brace, so I damaged the power supply to my seats. Once you find it, split it in half and look for any burned pinned connections. It will make sense when you see it.
Tim
Old Dec 28, 2017 | 10:38 AM
dkb123's Avatar
Default Thanks ...
Hey Thanks for the information ... I will look into that. I did seem to get them working but still some wonky operation ... the seats take an abnormally long time and the backs will burn you out.
I'll keep working on it ...
dkb123's Avatar
I will definitely do that. I can't find anything on that in the manual ... strangely. Maybe I overlooked it somehow ...
Thanks,
Nxsov180db
Oct 9, 2018 04:58 PM
Gunz
Sep 11, 2017 06:46 PM
Patches
Jan 27, 2013 07:24 PM
tony1969
Nov 9, 2007 03:17 PM
landsteam
16
Sep 18, 2007 07:35 PM
