Heat/ AC control issue
Old May 19, 2019 | 11:40 AM
JerseyCoast's Avatar
Default Heat/ AC control issue
2007 Adventurer package. Did aftermarket stereo over winter. I had 2 harnesses going into factory stereo ( was not monsoon. ) ran new speaker wires so not using the original set up.
I did search but could not find this exact issue. Blower control works fine ( already changed the recall issue) but I cant change temp control or the dash control ( from floor to vents to defroster) 2 out of 3 controls are not working.
Does that smaller harness have anything to do with these controls? I checked the plugs & wiring going to unit, they seem fine. Before I buy new unit, wanted to ask if maybe something was disconnected that was part of original stereo harnesses to control heat/AC?
I'm not a big coincidence guy....im thinking something may have caused this when stereo was changed...??? But the blower control still works fine.
Thanks in advance for any help here.
Old May 19, 2019 | 12:08 PM
WR3NCHE4D's Avatar
Old May 20, 2019 | 09:56 AM
Originally Posted by WR3NCHE4D
Tried it with no luck. The ac & defroster led's are Not working at all. How long does it take to calibrate? Maybe im not waiting long enough?
Old May 20, 2019 | 10:57 PM
WR3NCHE4D's Avatar
Time to go back to basics. Check ALL the fuses! There should be separate fuses for the blower motor and the HVAC unit.
Old May 21, 2019 | 07:27 AM
Try this, unplug everything HVAC (3 connectors) in the center stack, disconnect the battery (both connections) touch them together. Then reconnect everything. Battery first.
carloscrx101
Aug 23, 2023 09:57 AM
bflank
Dec 28, 2016 11:24 AM
Fla Grown
Jun 2, 2016 01:18 PM
angiebell71
Feb 2, 2014 12:19 PM
Harley100th
Aug 22, 2012 12:55 PM
