Headrest DVD Power
Old Nov 16, 2006 | 11:42 AM
tteazis's Avatar
Default Headrest DVD Power
Hi all,
I am trying to install the Vizualogic Headrest DVD system on my '07 H3 and I do not know where to get Constant +12V and Accessory +12V. I do not have the electrical schematics... [:@]
I already pulled 3 wires (Constant 12V, Accessory 12V and Ground) under the instrument panel. Where should I connect them???
I have a multimeter. I saw some unconnected wires for trailering (I think) under the stereo and some more next to the parking brake under the instrument panel.
Any help would be greatly appreciated.
Theo.
Old Nov 16, 2006 | 12:07 PM
dilo2001gt's Avatar
Default RE: Headrest DVD Power
Do you have power seats you can tap off the driverside or run it to the radio.
Old Nov 16, 2006 | 01:32 PM
tteazis's Avatar
I have the power seats and I already run wires to the radio & instrument panel. The GM DVD Installation instructions say the following:
"From vehicle accessory power, T-tap brown accessory wire to jumper harners and ground with 10mm bolt."
That accessory power is under the instrument panel. I looked but there are several brown wires there. One of them is in the bundle of unconnected wires that I saw. I am guessing that that might be the Accessory Power wire. Does anyone know? How about a Constant 12V wire?
I am used to working on classic cars with electrical schematics... I do not want to mess too much with my Hummer...
Old Nov 16, 2006 | 02:32 PM
importkiller's Avatar
you can use any of the switched 12 volt wires behind the radio for the acc. wire and use any constant 12v wire for your 12v.should be relatively easy if you have a multimeter.
Old Nov 16, 2006 | 05:10 PM
dilo2001gt's Avatar
I tap off my driver side no problems
[IMG]local://upfiles/111/EF6AEDAE85294C11B79AE3777863A381.jpg[/IMG]
Old Nov 17, 2006 | 03:34 AM
tteazis's Avatar
Thanks guys.
I ended up using the contant 12v and ground from the unused trailer wires behind the stereo. For the accessory 12v, I tapped into one of the wires going to the rear window wiper. I checked it with the multimeter. All these wires were close to each other behind the stereo cover area.
All is good now.
Theo.
Old Nov 18, 2006 | 09:32 PM
bradj89's Avatar
Theo:
Did you complete your install? I just ordered the Visualogis DVD headrests. Any chance you can email me the install steps?
thanks
pau23
Nov 11, 2014 10:20 PM
1wandering
Jun 12, 2014 04:17 PM
smileynialley
Sep 6, 2012 01:21 PM
dilo2001gt
Feb 13, 2006 10:25 AM
dilo2001gt
32
Feb 3, 2006 12:13 AM
