Headlights
Old Mar 3, 2010 | 10:05 PM
07H3X's Avatar
Default Headlights
Im getting ready to order some Nokya Xenon Headlight Bulbs and was wondering if i should stick with the 65/50w or is it ok to go with the 100/80, i had the 100/80 bulbs in one of my camaros and it never melted anything so im thinking its ok just wanted to check. thanks
Old Mar 4, 2010 | 10:45 AM
wfturner's Avatar
You might want to do a "search" on this forum for that particular wattage
My gut tells me that 100/80 bulbs might be too much for the factory wiring.
They do make wiring harness kits to solve that problem
I used a wiring harness kit to upgrade to 100/80 bulbs on my old vehicle
and it worked perfectly
You may already know this info
good luck
Old Mar 4, 2010 | 12:06 PM
07H3X's Avatar
Ya i know of the harness but ive used the 100/80 on a stock harness in a 02 SS Camaro and it worked perfectly but i dont know if the harness in the camaro is heaver gauge wire or not
Old Mar 4, 2010 | 12:55 PM
wfturner's Avatar
Years ago, manufactures realized that they could use the bare minimum in wire gauge to any and all electrical components, to save money
I had a 1993 Nissan Pathfinder and I believe the wire gauge to the headlights (right at the headlamp) was less than 20 gauge
This was way too light for 100 watt bulbs (100/80) which draw about 8 amps.
Maybe you Camaro had better wiring.
I know they will come on and work, but you don't want to heat up the wiring and get less performance out of you new bulbs
My 07 H3 looks like it too has rather light gauge wires to the stock bulb
good luck
Old Mar 4, 2010 | 02:01 PM
07H3X's Avatar
Thanks for the info, i will go with the 65/50 for now
Old Mar 4, 2010 | 08:50 PM
07H3X's Avatar
just ordered the 65/50 for headlights and 55 for foglights
Old Mar 5, 2010 | 02:46 PM
wfturner's Avatar
I hope they work great
The factory bulbs are really sad
I don't know anyone who has been happy with the factory headlights
Old Mar 5, 2010 | 04:03 PM
NJTEX's Avatar
My Pontiac uses the same bulbs in a bigger reflector assembly and it's passable. My guess is that H3 is the worst case of weak bulb and small reflector together. Silverstars helped but they only last a year in my daily driver H3.
Now I just use cheapie 110W KC driving lights switched on by the highbeam circuit. It's old school but it works for me.
Old Mar 5, 2010 | 05:58 PM
drtom's Avatar
Banned
Default 07h3x,info please
"Nokya Xenon Headlight Bulbs"??
could you point me to the supplier of the 100 watt bulbs pls?
oops, and part number!
tnx
tom
Old Mar 6, 2010 | 09:39 AM
07H3X's Avatar
ive used these bulbs 4 or 5 times and they are great, you can either get them from coolbulbs.com or you can save money and get them from ebay, just make sure you get the Arctic White! i saved 30bucks getting them from ebay on headlights and fog lights. heres the 100w and 65/50 part number
7227H13 / 900865/50$49.997228H13 / 9008 HI100/80$49.99
