Headlight bulbs
Old Sep 28, 2011 | 10:48 PM
Deputyj's Avatar
Default Headlight bulbs
Is there a certain way to get the headlight bulbs out of their sockets? Can't seem to remove them from my 07 H3?
Old Sep 29, 2011 | 08:15 AM
Super easy. Open the hood, reach in from behind the headlight and grab hold of the plastic ears of the bulb base and give them a 1/4 turn. Remember left loosey.
Old Sep 29, 2011 | 07:44 PM
Deputyj's Avatar
Default Thanks
But that's not the problem. I can manage that without issue. The problem is removing the actual bulb. I've pulled on it but can not remove it. Is there a way it has to be turned or something to that affect?
Old Sep 29, 2011 | 07:49 PM
wfturner's Avatar
The actual glass bulb and plastic base are one unit
Old Sep 29, 2011 | 07:52 PM
Mr. Fancy Pants's Avatar
lol...I laughed out loud and my wife looked at me puzzled....
like wfturner said, they are one unit and unclip from the back.
Old Sep 30, 2011 | 05:48 AM
IgottaH3again's Avatar
If you do touch the glass ... wipe it down with rubbing alcohol. Clean them thoroughly. It's the oil from your skin that causes a reaction with the glass.
Old Sep 30, 2011 | 06:00 AM
Deputyj's Avatar
Default Ok
Don't know how to explain it. Totally understand the bulb and the plastic base are all one unit. I've owned other vehicles and have replaced lights prior to this. I installed all my lighting in my H3 and re wired my fogs. But for some reason the entire headlight bulb, plastic base and all will not let me un plug it. I undo the small plastic clip from the base. But as I pull to unplug the entire unit. It will not budge.
Old Sep 30, 2011 | 07:09 AM
DAGKANA's Avatar
Anyway to get us a pic of the trouble spot? Is it gummed up w/ road debris perhaps? Hard to say w/o seeing it...
Old Sep 30, 2011 | 07:36 AM
Broken Halo's Avatar
Were the new lights you installed a higher wattage then OEM? Maybe you overheated the connector and melted it to the lamp holder?
Old Sep 30, 2011 | 07:39 AM
wfturner's Avatar
Bingo ! I'll bet that is what happened.
He will have to describe it better or pics will help. I don't really understand what he means by "re-wired"
