Headlamps , Foglamps question
Old Sep 16, 2011 | 04:11 PM
H2Miami's Avatar
Default Headlamps , Foglamps question
Anyone knows how to connect the fog-lamps (day-time lamps )to get it working at night along with the headlamps
Day-time only turn at daylight by the sensor ..
Thank you in advance
Old Sep 17, 2011 | 11:16 AM
fyr145's Avatar
Step 1
: get some 20g wire, a 200v 1amp diode (Radio shack PN: 276-1102)
Step 2
: Install the diode inbetween a line of wire. Or better put, get two pieces or wire and wire on to each side of the diode. You can solder it or wrap the wire around the
diode
wire and tape it up with electrical tape (NOT RECOMMEND, you should solder it)
Step 3
: Remove the Prk fuse 10amp and the drl fuse 10amp.
Step 4
: lift the park relay and drl relay and place the wire/diode ends (exposed wire) into the specific slots in the relay. 86/85 respectivily. Make sure the little grey strip,
the cathode side, is point towards the PRK RELAY 86. Also make sure the diodes wires arent exposed and not grounding on anything.
Step 5
: Replace the relays in their specific slots. Make sure to line them up correctly; they got numbers next to the contact points on the bottom so its really easy no to
mess this up.
Step 6
: Replace the fuses.
Step 7: Enjoy!!
Old Sep 17, 2011 | 11:18 AM
fyr145's Avatar
Forgot to mention that before removing the relays, pull the parking light and
drl fuses
to prevent potential shorts caused by the flat blade screwdriver.
Once the jumper has been installed, put the fuses and relays back, but don't fully seat it until after verifying that the lights work. This way, it won't be too much of a pain removing the relays again.
Old Sep 17, 2011 | 12:45 PM
drtom's Avatar
Banned
u mite wanna check the many posts in h3 section for some info,,,ez fix. h2 similar im sure
Old Sep 17, 2011 | 04:46 PM
H2Miami's Avatar
thanks a lot . I'll be working on it next week , I'LL post how it came out .TX
Originally Posted by fyr145
Step 1
Step 2
diode
Step 3
Step 4
Step 5
mess this up.
Step 6
Step 7: Enjoy!!
Old Sep 17, 2011 | 04:50 PM
H2Miami's Avatar
Couple questions
does it interfere with the auto light ?, also at day only the day-t lamps will be on? .tx
step 1
: Get some 20g wire, a 200v 1amp diode (radio shack pn: 276-1102)
step 2
diode
wire and tape it up with electrical tape (not recommend, you should solder it)
step 3
: Remove the prk fuse 10amp and the drl fuse 10amp.
step 4
: Lift the park relay and drl relay and place the wire/diode ends (exposed wire) into the specific slots in the relay. 86/85 respectivily. Make sure the little grey strip,
the cathode side, is point towards the prk relay 86. Also make sure the diodes wires arent exposed and not grounding on anything.
step 5
mess this up.
step 6
step 7: Enjoy!!
Old Sep 17, 2011 | 06:00 PM
fyr145's Avatar
no, the AUTO feature still works as it should. yes the daylamps will still work.
Old Sep 19, 2011 | 12:32 PM
Indy's Avatar
I remember there are some good write ups on this with pics....I did it myself and it works like a charm....good luck.
Old Sep 19, 2011 | 07:39 PM
Muddydawg75's Avatar
no.... it's not the same..... not even kinda close to being the same..... not even apples to oranges the same....
back to the topic.....
if you need a picture LMK.... the instructions posted are very step by step and very clear... but sometimes people want a picture...
Old Sep 20, 2011 | 04:48 AM
drtom's Avatar
Banned
h2 similar im sure
pls note my use of the word "SIMILAR",,,not "same",kinda like apples and pears similar
the concept is precisely the same,the physical hookup is similar.
no twisted wires,no taped up conn, a neat tidy secure job, and just trying to help
