the hi/low kit should Come with a harness.
do not need error cancelers mounting is up to you. I have mine zip tied in the engine bay, it all depends on how you want to mount them. |
i dont know what the error cancelers are but the other two things should come with the kit already. you do need them, more the wire harness then the mounting kit. i didnt use the mount brackets on my ballast. i just let the set down on the little 'shelf' area by the headlights.
What is and what does the error canceler do??? Sounds important.
It cancels errors
Originally Posted by Hummer72
(Post 297503)
Really hummm figured that much out. But is the HID lights gonna cause me to have errors?
Well do I need one???
(Post 297503)
(Post 297509)
Simple solution for you: 1- buy your hid kit 2- install 3- test a) no errors, no flickering; NO EC's needed b) errors or flickering; EC's needed simple plug and play if you need to install the error cancellers, connect one end to the HID bulb and another end to the ballast. |
none of my kits ever came with an error canceler and i've installed them on a lexus es300, a bmw 325, and a hummer h3. none of which ever threw a error code. i think youll be all set with out it.
That response was for Evan not anyone else. I really appreciate all the help with this. Keep talking I am listen...
