half of door locks are inop
Old Mar 12, 2011 | 08:05 AM
janet's Avatar
Default half of door locks are inop
I have an H2. It is a 2003 model. I am having a problem with my door locks. When I hit the lock button (whether it be the remote or the driver door switch) only the front 2 doors will lock. It will not lock the others. I have to manually lock the back doors. If I hit the unlock button it will unlock everyhting. Any Ideas? Also....the back hatch works intermitantly and the back lock/unlock button in the hatch area is doing the same thing....Any ideas?
Old Mar 12, 2011 | 10:14 AM
Mellilo's Avatar
Janet,
Since I can't check it out, I would suggest you have the solinoid checked out. If the solinoids check out you may have a bad/loose ground in the wiring. Solinoids are a few bucks (relative term) and generally easy to swap out. Juat make sure that all the wires go back in the same slots
Old Mar 12, 2011 | 12:43 PM
janet's Avatar
Default doors inop after cool down they work
does an 2003 h2 have servos for the driver door controls? and if so....where are they located at?
Old Mar 14, 2011 | 11:36 AM
Pauldy's Avatar
Probably not a solenoid but probably the door lock relay pretty easy to replace but kind of pricey at around 30 bucks a pop, you only need one right now but the other probably isn't' far behind.
Location should be in the compartment behind the battery, when you take the cover off it has a schematic so it shouldn't be hard to find. Just swap the front for the rear to test.
Crater
Jan 1, 2013 09:31 PM
Chad1996
Dec 1, 2012 02:21 PM
Rooster
Apr 4, 2012 10:39 PM
palmxjjsi
Jun 16, 2011 04:45 PM
dleotaud
Sep 14, 2009 06:05 PM
