H3 Tire Size
Old Mar 10, 2013 | 02:50 PM
jutt25's Avatar
Default H3 Tire Size
I have a couple of questions.
1). Just installed a Trailduty leveling kit(Bilstein Shocks, Extended bump stops.
What should the gap between A-Arm and bump stop be?
2.) What is the best tire size for this setup? Will the I-5 Base pull a set of 35's?
Old Mar 10, 2013 | 02:55 PM
Bunger's Avatar
Gap should be less than 1/4", touching is OK. They are not bumpstops, they are dampeners and meant to be part of the suspension system.
Thousands of people run 35's with an I5, even without leveling, and YES they may rub slightly on the swaybar when at FULL turn.
Old Mar 10, 2013 | 05:41 PM
NJTEX's Avatar
285's are my favorite size, some like larger. Stock bumpstops are best for off-road crawling. If on-road performance is more important for your useage, go with the 1/4" recommendation.
Don't forget to get an alignment done every time you adjust your torsion bars!!!
Old Mar 10, 2013 | 06:24 PM
skeeter's Avatar
A lot of people are running 35s on trucks with i5s, but I personally would do some upgrades to the motor if you want to run 35s all the time. I do run 35s with an i5, and I have done a lot of motor upgrades and I can run down the highway pretty well except for big, long hills
Andreas_Sweden
Mar 19, 2025 12:16 PM
Hummer79
Jan 7, 2013 11:28 PM
importkiller
Oct 5, 2012 05:51 PM
IN2deep
Oct 15, 2007 09:23 PM
jbb6811
Mar 24, 2006 03:43 PM
